0 Members and 1 Guest are viewing this topic. Read 9476 times.
I believe their posting in the All Solid State circle answers that question. My recommendation, which I replaced with Emily Litella's famous, "nevermind," was for a tube preamplifier. Martin
Merrill Audio "Cara", has received very favorable reviews.
If wanting SS, I would recommend the BAT VK-42 and 43se models which still have the BAT sound as well as a Pass XP-10, 20 or their newer XP-12 and XP-22. The Pass preamps tend to sound excellent at low volumes. They keep their dynamics. The Parasound JC2 preamp is also awesome. Black background, neutral, very transparent and detailed. It needs to be paired with an amp that has a heavier mid range though. It is still a stereophile Class A preamp.
I will check out the Pass preamps. I initially wanted SS as its easier to move around and have certain consistency. But considering so many recommendations of tube based preamps, I am rethinking.
Hi Martin,I posted it in All Solid State, but so many recommendations to look at the tube preamps has gotten me thinking and also interested to look at the tube based preamps too. One strong candidate I am considering Aesthetix Calypso. Seems for the price is a good choice.I have a had some great recommendations.One a different note, what circle do you recommend this thread be moved to if tube and solid state both are contenders.
I am looking to try something new. Any recommendation on a stereo preamp with XLR outputs with remote control?
Well then let’s think big in terms performance ... something that could be considered “exemplary” regardless of cost. Check out Steven Stone’s review of the NuPrime DAC-10... it’s a fully balanced preamp with an integrated DAC that allows the option of selecting either 4 or 6 volts out. The volume “control” is second to none, and the metal remote is very nice too. Visually, it’s rather a plain piece but sonically it performs at the highest level.
The NuPrime and most other balanced pre-amp connections do not operate at high enough voltage to get the real benefit of a balanced topology. Benchmark published a good technical article on this after the thread died down in April: https://benchmarkmedia.com/blogs/application_notes/balanced-vs-unbalanced-analog-interfaces
Agreed, but would qualify your comment by specifying "most consumer balanced pre-amp...". I'm currently looking at a the German made RME ADI-2 DAC which has preamp, DSP, and headphone facilities plus excellent sound and +13 dBu output for $1100 USD.
Thank you for recommending Merill's Cara. I had not thought about it. I will be using Hypex amps and Cara might a good match as Merill sells Hypex amps and probably have voiced the preamp to have good synergy with Hypex amps.
