SOLD!!! SCHIIT FREYA Preamp W/ Remote - ships in original packaging
0 Members and 1 Guest are viewing this topic. Read 1178 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
FS: SCHIIT FREYA Preamp - W/ Remote - ships in original packaging   $ SOLD!!! Plus Shipping.
PASSIVE, JFET BUFFER or TUBE GAIN selectable.  Balanced and RCA Outputs.
Very good condition,  I wanted to try something different with my Musical Fidelity Amps and this unit did a great job, however,  A McIntosh MC110z project has moved up in the priority queue.
stock tubes - ( one has a broken guide pin,   I have a spare NEW unused Electro Harmonix 6sn7 to offer if that's a neg for you and will include it at your request)
Here are the finer details:
Input Impedance: 10K ohms
Crosstalk: >75dB, 20-20kHz
Inputs: 2 XLR pairs plus 3 RCA pairs, selectable via front switch or remote
Outputs: 1 XLR pair plus 2 RCA pairs, selectable via front switch or remote
Volume Control: relay-switched stepped attenuator with discrete thin-film resistors, 128 0.625dB steps
Power Supply: One 48VA transformer with regulated 300V rail, plus 24VA transformer with regulated +/-20C rails, plus 6.3VAC tube heaters and regulated 5VDC for microprocessor
Power Consumption: 40W typical
Size: 16โ€ x 8โ€ x 2โ€ + tube height (about 2.5" more)
Weight: 11 lbs
JFET Buffer
Gain: 1
Frequency Response: 20Hz-20Khz, -0.2db, 3Hz-500KHz, -3dB
THD: <0.001%, 20Hz-20KHz, at 2V RMS
IMD: <0.0015%, CCIR
SNR: >110db, A-weighted, referenced to 1V RMS
Output Impedance: 75 ohms SE, 600 ohms balanced
Topology: Single pair JFET per phase with passive distortion cancellation, DC coupled
Tube Gain
Gain: 5 (14dB)
Frequency Response: 20Hz-20Khz, -0.2db, 3Hz-200KHz, -3dB
THD: <0.01%, 20Hz-20KHz, at 2V RMS
IMD: <0.01%, CCIR
SNR: >95db, A-weighted, referenced to 1V RMS
Output Impedance: 210 ohms
Topology: differential input/output, pure triode, with low impedance followers
« Last Edit: 6 Apr 2018, 01:23 pm by Bostown »
Goosepond
  • Virna!
PM sent.
Gene
