SP2 - using XLR and RCA outputs simultaneously
0 Members and 1 Guest are viewing this topic. Read 883 times.
alexone
« on: 3 Apr 2018, 06:28 am »
James,
i'd like to use both outputs of my SP2 (xlr + rca) at the same time in order to biamp my speakers. i understand that both outputs need the same gain (23 or 29db), which can be chosen on the amp's backpanel.
would this setup work fine or should i expect any problems??
thanks,
al.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 - using XLR and RCA outputs simultaneously
« Reply #1 on: 3 Apr 2018, 07:20 am »
James,
thanks,
al.
Hi
It should be fine other than watch out for ground loops.
james
