Hey Jeff,
Suffice to say, your AC line isn't set up to do duty as audio or video ideal...it's designed to makes appliances, lights turn on and run, etc. High fidelity, and later video, came around far after the advent of AC of course and hasn't changed much in the past decades.
I've never quantified the quality in any house I've lived in.....but have found improvement in early every hifi equipment and video equipment I've used with even a modicum of clean power and filtration. I have a little Monster Cable PowerBar and CyberPower UPS on my video system and they both helped quite a bit...for a cost of only about $275 for both.
These digital amps have much higher resolution than SS and tube amplification devices...the noise floor is lower (in an absolute sense) and the resolution is just greater. You tend to hear the flaws in the mains power quite a bit more acutely than SS or tube equipment.
I had the PS Audio PP300 Power Plant for a while. It helped my (then) solid state amps mostly...but added to much back that was objectionable. I bought the BPT unit and it improved, however I was more aware of the deficiencies of those SS amps when I did (note: the sound you hear is only as good as it's weakest link in the chain).
Using the JVC in conjunction with the BPT provides a really great match. Both are high quality: the JVC has wonderful resolution but must be fed absolutely clean power. If I could run it on clean pure DC I would...barring that the BPT is nearly as effective. The BPT improved the resolution of my DAC based front end, too..rather dramatically.
My BPT has considerable upgrades that help things further; upgraded litz cord, ers cloth within, internal and extenernal ZSleeves, hi-frequency filter and mechanical isolation footers. They all served to make the BPT better by feeding the JVC cleaner power. It's absolutely essential for digital or hybrid digital amps to have the best power you can provide them.
Barring and investment of $1500 in the BPT (other models go for more, too, and balanced power units from other makers that are probably good, too), there are lesser clean power alternatives that will help.
Simply changing out your $.50 outlet to a good $40 audiophile one (I have heard that the cryo'ed ones are truly better, but not heard it myself to know) and shilding the JVC cord (with ZSleeve, ers cloth or $25 Highwire PowerWrap) will be an inexpensive lesson as to how important EM and RF filtration is to digital amplification. For very little, they will help you get the best from your JVC. Add a good power filter and you will advance further; add a Balanced Power unit and upgrades and you will get further. It's just a matter of how far you want to go, and spend, to achieve your 'nirvana'.
The absolute top stud-muffin that I know of in knowlege about digital amplification and clean power is Mark Hampton of ZCable. He's a down to earth, soft spoken Nebraskan that is patient if you need questions answered. He set me on the right trail about a year ago when I bought ZSLeeves from him. If you're a believer in digital amplification, or believe you might be, you owe it to contact Mark and get the scoop.
Mike of CryoTweaks is probably a good second and has a terrific selection of stuff to choose from, as well.
I'm not in the least affiliated with them/him, but I think their advice is stellar in this category
