FS:HiDiamond D8 speaker cables 2.5/M (8 feet)
0 Members and 1 Guest are viewing this topic. Read 873 times.
Lak
« on: 25 Mar 2018, 06:32 pm »
I Purchased this new pair of HiDiamond D8 speaker cable from an authorized dealer in 2014. Amp end has spades and the speaker end has locking bananas. They are fully broken in and rated at a 9. These are truly an outstanding speaker cable and the only reason I’m selling them is that I have a new set up in my system I require a 10’ pair of speaker cables.
Located in Perrysburg, Ohio 43551. Asking $1300, or best reasonable offer. Please contact me directly at Lak9@bex.net, (Audiogon username Lak)
From the HiDiamond website: Cable with proprietary 4VRC©, copper cooking for four times in order to obtain a reduction in values of inductance, capacitance, and resistance. Isolator in XLPE where XLPE and 100 times better than normal Teflon. This lowers the threshold of escape of spike, cancels the skin effect between individual leads and therefore the width of the musical signal barrier guaranteeing greater linearity and low amplitude of the sine wave of the basis for the benefit of the naturalness of musical signal emission. Terminated with connectors to high-quality Rhodium great plating that allows a better signal transmission without loss and oxidation power void. Technology twisted within the cable to get a balanced sound across the frequency band tonal with a powerful bass extension and precise and this leads to sound science fiction, the incredible dynamic like a hairdryer will send a large amount of air around the hair, giving an impression of dynamics in complete freedom without any compression, a medium-low which helps to give force to the reproduction , snug and warm voices to emphasize the details of recording, precise focus, high transparent never aggressive. Impossible to put it into crisis.
Redefines the way you listen to, the point of arrival. A cable that is present but does not feel. Shown in all systems and valves of any solid-state solid value. 16 x 2,5 mm conductors 4VRC©. An absolute reference.
Technical characteristics:: External jacket mm. 270 ; Number of Cond. 16 ; Cond. Copper (4VRC); Capacity max. 55 Pf/m.; Conductor Resistance: 7,98 Ohm/km.
Buyer Pays Shipping and Paypal fee of 3% if used. I will accept United States Postal Order, Certified bank or personal check after it clears. Local pick up available.
BUMP
« Last Edit: 21 Apr 2018, 01:45 pm by Lak »
Lak
Re: FS:HiDiamond D8 speaker cables 2.5/M (8 feet)
« Reply #1 on: 12 May 2018, 02:09 pm »
Bump
