0 Members and 1 Guest are viewing this topic. Read 8283 times.
Just try twisting about 2" OC. Should be just fine. Make a positive run then a negative run meaning two separate wires. charles
I took four wires (14g.) and wound them together the length of the cable.My question is - is there any benefit or "negative" effect i.e. what changes occur, by winding the 2 negative and the 2 positive separately and then hooking them up? (They are 25 foot lengths.)
Inductive reactance is frequency dependent. For comparison, below is the DC resistance, the straight wire inductance, and inductive reactance for 5 feet of single wire and parallel wires at 20khz: Single Single Single 10 parallel18 gauge wire 13 ga. ~9 ga. 18 ga..0325 .0104 .0066 .00325 DC resistance2410 nh 2232 nh 2162 nh 241 nh.30 ohms .28 ohms .27 ohms .03 ohms Inductive reactance at 20khzNotice the 10 parallel 18 gauge wires equate to an approximate 9 gauge wire in DC resistance, but the inductive reactance is only 1/9th that of the 9 gauge wire. (You may have heard the past arguments over the small wire parallel with the large wire improving the highs. The highs were increased because the inductance of the two wires was about 1/2 that of a single wire.)Remember, this is for a single 5 foot lead, not both leads. Multiply this by 2 for the total 10 feet speaker lead length. I would say .54 ohms is quite a bit in series with a 4 ohm, or 8 ohm speaker, although the impedance of a speaker at 20khz is higher. I and friends perceived a difference in my system between 8 and 10 parallel conductors per + and per - leads.
Wow - it's a bit hard to say what to make all of this.It's good to increase capacitance and reduce inductance (the resistance to change in the amount of current) in a speaker cable. It seems like more small gauge wires twisted is best? I'm not sure. It's all a bit confusing.But then again, if it was all straight-forward I guess all the high-end speaker cables would have the same number of same gauge wires twisted together.
While I'm thinking about it:Most conventional loudspeakers (but not all) have raising high frequency impedance, so cable inductance deosn't matter. But for those special case loudspeakers, cables with low total inductance will be brighter than high total inductance. I have seen cables with the conductors separated by 18 inches to reduce brightness.
Oh dear, oh dear.There are many different inductance formulas. Sometimes it's easier to just measure it than to find the correct formula.Just borrow an inductance meter. Take two long wires (ordinary electric wire will do). Connect them together at the far end. Separate the two conductors into a loop and measure the inductance. Then twist the two conductors together and measure the inductance again. The twisted pair will have much lower inductance.
L = Z0 / (c * Vr) (5)2.2 Inductance at direct currentThe internal inductance of electric cable varies by frequency. Maximum internal inductance is obtained at direct current. For non-magnetic cylindrical conductor, this maximum value is as follows. Li = 0.05e-6 (H/m) (7)For the two parallel wire cable, we can estimate the DC inductance value by adding (5) and the twice of (7).
charmerci, I would follow your thoughts, or even more smaller wires in parallel if possible.Charmerci, your idea has merit, even using 5 smaller wires in parallel.
................................I would think that less resistance (helllooo superconductors!), high capacitance (storage of the energy) and less inductance (resistance to change of that stored charge) would be best. But a thick, not twisted solid wire increases the inductance, right?
So rather than borrowing test equipment and setting up a test, I found a little calculator program that will do the work for us:https://www.eeweb.com/tools/parallel-wire-inductanceUse the parallel wires calculator. You might have to work to find values that are in the calculator's range.You will see that as you increase the 'Distance between wires' value, the inductance increases.
