0 Members and 1 Guest are viewing this topic. Read 54421 times.
Thats a kit I've been very interested in building since first reading it was in the works.
Mike, you need to get out more! Boring speakers that have been done 1000x before...
Spinners are either a Luxman D-05 SACD/CD or an Arcam FMJ CD37 for background listening. Maybe when the day comes and I retire I'll pursue migrating my hard media and converting some of my couple thousand lps to files for a DAC based system.
Do you really want to start this debate all over again. I guess 17 posts before it hits the Intergalactic Waste Bin.
There won't be a Class D revolution until Class D amps are made to also weigh 100lbs. That simple. If you are shelling out big bucks for an amp the perception is, right or wrong, it's gotta have real heft. A fat number to slap on the brochure and website. Cause you're not buying it off Amazon, ur goin to a dealer and saying you want the Fire, the dank. That dealer is not gonna wanna take you to a room where there's a small box that weighs 10lbs. He is gonna want to take you to a room so he can say it's so heavy I have to bring you to it. It takes two men with strong beards to set this up. It has fins, because the HEAT. Requires cables the thickness of an arm, a STRONG arm. The GIRTH. And you say, mmmm, take my money.That dealer is not going to want to take you to a special room and show you an amp that can fit in Amazon frustration free package no matter how blinged out the enclosure and tell you about how simple it is, how technologically advanced it is, how it slides right next to your AppleTV, and the space age design. You're gonna go, huh, bet my significant other would love that. How many men does it take to lift the other one again?
That might be true for the simple minded
Yikes.
Also, I'd just like to point out the possible misinterpretation of the words 'SS Revolution'.
