0 Members and 1 Guest are viewing this topic. Read 4622 times.
The only place in hi-fi that static electricity can be a problem is in the act of connecting interconnects to sensitive input circuits.
...seriously, you are never going to get any agreement as to whether they work. Like all tweaky things, system differences, resolving capabilities, and belief systems of the listeners will contribute to different perceptions as to whether these things work.
Let's not forget about the pesky static charges that have to be dealt with when playing vinyl records in cold dry weather!
I use them now because they look better and keep dust from collecting on them...and they were given to me (thanks TomS)
Save your Bathroom toilet tissue rolls for awhile.
Put me in the "Yeah, whatever" camp. Even if 'tweaks' help, their "benefits" are greatly overstated. My main issue with tweaks is that they are too often a band-aid on the elbow for a skinned knee. Browse through the Pictures section and you will see literally dozens of systems where large amounts of $$$ have been spent on things like cabling (signal AND power) while obvious, real, visible LARGE problems were ignored: Planars in front of large glass surfaces; speakers with totally different room loading left-to-right; speakers a foot and a half from TT's (and in the corner too in one example I saw recently); large glass cabinets taking up almost all the space between the speakers (one of which was in a order and one at the other end of the wall radiating into open space) etc etc etc. All of these examples I'm thinking of appeared to be systems where well into five figures was probably spent, a lot of that on 'tweaks', without a dime to address obvious room/placement issues. (As JLM says, "The elephant usually IS the room.") Spend your money on these things if you like, but if you don't address the big problems first, you are wasting at least 99% of it IMO.
I use wooden cable risers on a wooden floor strictly for aesthetics. I use component isolation devices for the same reason. Yes, I believe they make a subtle improvement, but more importantly, they make your gear appear as though they're floating.If a tweak doesn't look good, it doesn't sound good. That's my philosophy.
