Can CDP-9 replace DAC-9's preamp
kaka89
« on: 5 Mar 2018, 06:03 pm »
If I want to upgrade to CDP-9, do I need to keep the DAC-9 for its pre-amp section?
I am pairing with STA-9.
Thanks.
left channel
    • Everyone wants to date my avatar
Re: Can CDP-9 replace DAC-9's preamp
« Reply #1 on: 5 Mar 2018, 06:43 pm »
The CDP-9 has its own DAC and preamp as well as digital outputs, but you may want to hang onto the DAC-9 for now just to compare. I believe the DAC designs are very different.
rustydoglim
    • www.nuprimeaudio.com
« Reply #2 on: 5 Mar 2018, 08:26 pm »
CDP-9 uses ESS9028 DAC, sound wise no different from ESS9018.
But then as we keep saying, the performance is not due to the DAC chip anymore.
All sorts of circuit and features other than the DAC chip determine the performance.
DAC-9 sounded warmer but not as detailed as CDP-9 or DAC-10.
left channel
« Reply #3 on: 5 Mar 2018, 09:16 pm »
Thanks for the additional detail, Rusty Dawg. I really like the DAC-9, and in general prefer DACs designed around AKM chips like the AK4490 EQ in the DAC-9, whatever the reason.
@kaka89 looking forward to hearing your impressions when you can compare them both.
