Introducing ApplePi DAC -- Highest Performance Raspberry Pi DAC
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #100 on: 30 Aug 2018, 04:53 pm »
What other inputs are available besides SPDIF?
SPdif only.
Here is picture of the back:
Shakeydeal
Re: GALA DAC
« Reply #101 on: 30 Aug 2018, 05:58 pm »
Will this be available with single ended outputs?
Shakey
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #102 on: 30 Aug 2018, 11:25 pm »
Shakey
It will be XLR only but you can easily get a single ended output by using a cable like this:
https://benchmarkmedia.com/products/benchmark-xlrfm-to-rca-adapter-cable-pin-3-floating?variant=547648461
Single ended the output voltage will be 2.5Vrms
Be carefuly of standard XLR to RCA cables, they ground Pin 3 to chassis which would not be good for this DAC.
poseidonsvoice
    • 2 channel/7 channel setup
Re: GALA DAC
« Reply #103 on: 30 Aug 2018, 11:31 pm »
Be careful of standard XLR to RCA cables, they ground Pin 3 to chassis which would not be good for this DAC.
Very important point - thanks for making that clear.
Best,
Anand.
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #104 on: 7 Sep 2018, 01:22 pm »
Anybody interested in the tour?
orchardaudio
    • Orchard Audio
We are celebrating the opening of our online shop. Get 10% off ApplePi DAC:
https://orchardaudio.com/shop?olsPage=products%2Fapplepi-dac
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #106 on: 25 Sep 2018, 12:40 pm »
For anybody who is interested:
charmerci
Re: GALA DAC
« Reply #107 on: 25 Sep 2018, 04:57 pm »
I would be interested - but I don't want to spend $46 to listen to it.
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #108 on: 3 Oct 2018, 12:28 am »
Last chance to sign up to receive an extra 10% discount on launch day:
https://www.indiegogo.com/projects/gala-ultra-high-performance-stereo-dac/coming_soon/x/19247162
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #109 on: 3 Oct 2018, 12:28 am »
If you sign up for the mailing list you will be able to get GALA at additional 10% off which is $50, then you can get the cables... :D
orchardaudio
    • Orchard Audio
Case for ApplePi DAC...
Thanks to one of my customers (Rick D.) I can say that the HifiBerry Universal Case, fits the ApplePi DAC perfectly:
https://www.hifiberry.com/shop/cases/universal-case-black/
I would highly recommend getting these heat sinks for the DAC chips:
https://www.newark.com/fischer-elektronik/ick-smd-a-8-sa/heat-sink-dip-ssop-tssop/dp/34M6428
In addition to the heat sinks I additionally recommend drilling a few holes in the top cover to improve airflow.
The case will not work with ApplePi Volume-Clocker.
Here are some pictures:
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #111 on: 5 Oct 2018, 12:08 am »
With all the work and running around trying to get the Indiegogo project running, I never had the time to sit down and properly listen to GALA.
Finally got GALA hooked up to my entertainment center, it sound much better than I could have imagined. It's hooked up to a pair of my own custom designed 25W mono-blocks.
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #112 on: 5 Oct 2018, 03:13 pm »
I just received word that GALA will be certified under the Arrow Certification Program - http://enterprise.indiegogo.com/arrow/.
This is a big advantage for this project as Arrow's engineers have rigorously reviewed all aspects of the design and confirmed that it either meets or exceeds all current industry standards.
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #113 on: 10 Nov 2018, 02:16 am »
The GALA project will be launching on Tuesday Nov 13th, 2018.
If you singed up for the mailing list, please be on the lookout for the special link around that time to receive your discount.
The discount will only be available for 24 hours from launch.
Please share this project with your friends, family, coworkers and on social media to help it succeed.
Mailing list link:
kbuzz3
Re: GALA DAC
« Reply #114 on: 10 Nov 2018, 02:36 pm »
Wish it had a usb input  :(
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #115 on: 11 Nov 2018, 03:38 pm »
You can very easily use it with USB by getting a USB to SPdif converter, this one is very good and very cheap:
https://www.ebay.com/itm/USB-TO-SPDIF-Converter-Coaxial-Optical-HA-info-PCM-AC3-DTS-Support-Source-Output/332782780592?hash=item4d7b6640b0:g:OGYAAOSwA7dbhWKu
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #116 on: 13 Nov 2018, 05:06 pm »
orchardaudio
    • Orchard Audio
Re: GALA DAC
« Reply #117 on: 16 Nov 2018, 12:34 am »
Help me spread the word about my GALA campaign and earn 10% commission!!!
Register at this link:
https://gala-ultra-high-performance-st.kickbooster.me/boost
richidoo
Re: GALA DAC
« Reply #118 on: 16 Nov 2018, 02:36 am »
GALA is now launched:
https://www.indiegogo.com/projects/gala-ultra-high-performance-stereo-dac/x/19247162#/
Congratulations Leo!!
I'm looking forward to hearing this one sometime.
Rich
orchardaudio
    • Orchard Audio
Re: Introducing ApplePi DAC -- Highest Performance Raspberry Pi DAC
« Reply #119 on: 19 Nov 2018, 09:43 pm »
20% off all ApplePi products until Nov 30th. Get yours now:
