Don't forget about the ceiling!
0 Members and 1 Guest are viewing this topic. Read 5219 times.
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #20 on: 7 Apr 2005, 09:40 pm »
adhesives that are designed to be removed from any surface should be fine but I've had trouble even with those (it was a 3M brand double sided adhesive pad that said it was safe for paint but ended up pulling paint off anyway).
I think the best trick with Foam is to use pushpins.  They'll leave small holes in the paint/drywall, but that is easily repaired with a dab of paint, or spackle or both. :wink:
michaelv
« Reply #21 on: 7 Apr 2005, 09:51 pm »
How many pins did you use for one foam of 12"x12" . Certainly, i  wouldn't want to put more than 4 pins per foam. So you push pin at the bottom edge? i will use pin to hold foam on ceiling . It's a better way  and thanks for suggestion.
LordCloud
« Reply #22 on: 7 Apr 2005, 10:44 pm »
Ryan,
How's the dedicated room going?
