Hestia New build
0 Members and 1 Guest are viewing this topic. Read 2104 times.
bear-hifi
Hestia New build
« on: 23 Jan 2018, 01:38 pm »
Really like the project and it has been fun. Thank you matevana!
I went with two MCM 15” woofers with a JBL amp crossover built in.  Peerless silk dome waveguide tweeter with (I think) 5uf cap and a L-pad.
I notice the mid can have a little shout at times. Was wondering about changing the mid to a Eminence Patriot Lil buddy?
matevana
Re: Hestia New build
« Reply #1 on: 26 Jan 2018, 02:22 pm »
You can try an 8 or 10 ohm resistor across the terminals of the MCM 10" driver. The Lil' Buddy driver sounds a bit darker, but the thick hemp cone tends to make the roll-off sound smooth. While it's fun to experiment, you can often save yourself some time and expense by using a good sim program upfront. It's helpful to think of the project as a system; one small change can affect everything. Enjoy!
bear-hifi
« Reply #2 on: 29 Jan 2018, 09:50 pm »
Thank you for the info!
