0 Members and 1 Guest are viewing this topic. Read 3171 times.
I thought the USB input on the Hegels are a strong point.
Several reviews I read on the H80 preferred the S/PDIF connection to the USB, as well as allowing 24/192 vs 24/96 if that makes any difference relative to one's library.Of course that would require acquisition of a USB > S/PDIF converter.
Yeah, I was disappointed too when I found out that my MBA lacked optical output. But I run mine via a 10 foot USB cable to my DAC (see my system and review in Critic's Circle of 9 cables). My favorite USB cable ended up being a $74 Straight Wire. Note that I only run ripped Redbook.
Don't understand in general why a separate USB/SPDIF convertor might sound better than running USB straight into a DAC. You'd be running a USB signal, a convertor, and a SPDIF signal versus a straight USB signal.
Meridian (Explorer 2 at least) allows for full MQA playback, but I fully expect the Hegel to sound better (plus or minus the remastering of MQA).
That leaves me scratching my head over perhaps 15 or so SACD-only discs that will just sit on the shelf until there's a good solution for ripping those.
I've heard that those can be ripped with an original PS3 or some models of the Oppo player.
Fortunately the cable maniacs have, for the most part, been stymied at USB by the notion that it's digital, so it shouldn't sound different. But that hasn't stopped most of the audiophile brands from offering overpriced USB cables.
I think you and I are closer to agreeing than you may realize.
I have a few SACD’s and a full function Pre-Amp. I recorded my SACD’s as follows: SACD player>tape In>out to computer. I use Audacity for recording.
