Bryston 7b3 upgrade to 28b3
ngamountains
Re: Bryston 7b3 upgrade to 28b3
« Reply #40 on: 11 Mar 2018, 11:20 pm »
We have similar systems zoophaugus.  I have the yggy dac as well feeding an arc Ref 5se, feeding 7b3 amps... I use a bdp2 as the player.  The sound is great.  I just made the jump to the 28b3 amps and should receive them soon.  I hope to hear the improvement others mentioned on the thread.
Will be interested to hear your thoughts on the 28s once you get them, especially as compared to the 7s. I just got 28 Cubes myself and though they are my first Bryston product so no Bryston comparator, I am thrilled with their sound. I have a Bryston BP26 and DAC2 coming Tuesday to try out with them.
clive101
« Reply #41 on: 14 Mar 2018, 04:31 pm »
I now have my amps up for sale so when they are sold I can order the 28b3.
« Last Edit: 16 Mar 2018, 08:14 am by clive101 »
TJ-Sully
« Reply #42 on: 16 Mar 2018, 01:13 am »
Right on Clive! Good job  :thumb:
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #43 on: 18 Mar 2018, 11:47 am »
I am late to the post
I have always had Bryston
I have owned most amps ST,SST,SST2
Recently move to new house purchased a 4B3 for a 30X22 room,,,,very nice sound so nice i moved up to the 7B3
Room still not finished,i am using FS-788 speakers i have owned for a very long time
I am thinking for a box speaker the 7B3 should be enough
Did you think of a loaner set (28B3 )to test in you home
Here is my set up
clive101
« Reply #44 on: 22 Mar 2018, 02:04 pm »
Hi tie-breaker, have the 28b3 amps arrived yet please let us know how they sound compared to the 7b3 amps..?
clive101
« Reply #45 on: 3 May 2018, 07:01 pm »
I thought I would update the post, I will have the new 28s for demo early June....
schmidtmike76
« Reply #46 on: 5 May 2018, 01:00 am »
We’re you in the Cyrus line at one time.  Maybe what hi if? I recognize your user name
zuluwarrior0760
« Reply #47 on: 5 May 2018, 04:46 am »
I went from 7bsst2s to 28bsst2s a couple of years ago.
For me it was the extra headroom with my current hungry Magnepan 3.7s in a large room.....
For you, I think the 28's would be massive overkill.  The $$ could do you more good elsewhere......
You're overpowered as it is........unless you're listening in a hotel ballroom
clive101
« Reply #48 on: 12 May 2018, 07:37 am »
I do agree with the power issue. Well powered up with the 7b3 but is it more a matter for control....?
I listen at low levels,  when I crank up the volume medium to loud the speakers do start to sing better....so perhaps the larger amps will help me....?
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #49 on: 13 May 2018, 08:24 am »
If I were you I'd spend some money on a guy specialized in room acoustics. That would benefit you a LOT more than just buying bigger amps.
clive101
« Reply #50 on: 13 May 2018, 10:40 am »
Yes I do agree.... but it's taken 18 months to get the wife acclimatised to the speakers....!
However, I am going to look into this but the sound seems pretty balanced IMO, which is astonishing, a few dealers unrelated to the purchase of the equipment have commented how balanced the sound is.
Even so, there is always be room for improvement.... no pun intended.
I will update on this matter in the next few months, thank you for the advice.
clive101
« Reply #51 on: 13 Jun 2018, 01:33 pm »
The pair of  Bryston 28 b 3  have been installed
audio.bill
« Reply #52 on: 13 Jun 2018, 05:47 pm »
And... what's the verdict??? Hope you get many hours of listening enjoyment with them!
TJ-Sully
« Reply #53 on: 13 Jun 2018, 08:18 pm »
congratulations Clive101!! right on.
got pics?
TJ
turnovertherecord
« Reply #54 on: 14 Jun 2018, 09:05 am »
Very nice,,,,,enjoy
clive101
« Reply #55 on: 14 Jun 2018, 01:43 pm »
Thank you for the recent comments of support, the 28b3 (s) are demo units and in black and my system is silver so unfortunately no photos.
I had too many other commitments so was unable to do a detailed session with them but...…
I do not wish to put down the 7b3 I had 18 months with them and enjoyed every moment but these beasts are different and for me " Low Level Listening " I am immersed in the music at low level volume where as the 7b3 were just playing music not singing to me. The 7b3 needed little more volume to get my PMC MB2se singing.
With the volume turned up say loud speech to very loud TV playing the 28b3 were still better by a long short, sound stage wider, strangely I thought lower noise floor, overall a very mature sound.
Bass better controlled and tight slightly more bass, more gravitas in mid range and more rounded treble. I could go on but will wait until the weekend when I can get a better listen.
The next question is to ask myself, " Is the extra spend worth it " ….?
If you have to think too long the answer is usually no.
Well pretty much made up my mind, I normally decide quickly, but will make a final decision over the weekend.... more to follow....
clive101
« Reply #56 on: 29 Jun 2018, 08:37 am »
I thought I would up date the post....
I decided to make the purchase...... however there seemed to be a mix on the part ex price with me and the dealer  :scratch:
So very close to pulling out of the purchase until the 7b3 sell privately and or the matching BP26, which may be as well as, Camjam London is soon to start and I may divert funds to my headphone ring...!
Overall the 28b3s are a beast of an amp and grip the speakers ( it's not about the volume ) its more how it controls the speaker. My advice if you can afford the 28b3s it's a no brainer to purchase they sing where as the 7bs can be a little shouty buy comparison, although it seems at the moment I be using the 7bs for a little longer.
I still like the 7b3s it's just when you try the 28b3s your put into a different league .
95Dyna
« Reply #57 on: 3 Jul 2018, 01:46 am »
Was the client using the same speakers you have?  I would arrange with the dealer to have an in-home demo for a week so you can listen to the 28B3 and compare it carefully to the 7B3.
My room is the same dimensions as yours. I recently sold my 7Bsst2's and BP26 and replaced the with the Esoteric F-05 integrated amp after auditioning the 4B3/BP173. The F-05 significantly outperformed both at 120/240 WPS. My speakers are 91 db and 8 ohms nominal 3.7 min. FWIW.
clive101
« Reply #58 on: 28 Jan 2021, 10:49 am »
After 3 years I am about to revisit idea of making the purchase of the mighty 28b3 amplifiers
G E
« Reply #59 on: 28 Jan 2021, 05:05 pm »
The 28's are fantastic.  I have had mine for almost 6 years.  The grip on the music ... yet all plays with a sense of ease.  I don't know how they bring such power and sweetness together in a kilowatt amp.
My preamp is the Pass Labs XP-32.  Just got it after having the XP-22 in house for 4 months.
Absolutely a magical combination!
