4B Cubed... what an amp!
0 Members and 1 Guest are viewing this topic. Read 1106 times.
jimangie1973
« on: 11 Jan 2018, 12:14 am »
After having the 4B cubed for almost 2 months,  I'm still thrilled at how good my system sounds.  I can crank it up with zero fatigue.  It is so smooth yet the bass is just slamming rock solid.  Wonderful amp!
I'd also like to thank Mike Pickett for helping me out with a couple issues.  First with a replacement unit after a buzz problem on the original I got, then with a cosmetic issue on the replacement unit.  Service was initially slow due to a miscommunication, but after that Mike was great.
Glad I could support a company that supports local manufacturing and really cares!
dznutz
Re: 4B Cubed... what an amp!
« Reply #1 on: 11 Jan 2018, 03:34 am »
What are you comparing the 4B against?
jimangie1973
« Reply #2 on: 11 Jan 2018, 01:05 pm »
Parasound A21
4BSST
3BSST
Adcom GFA-5500
SST amps sound very similar but don't seem to have the bass resolution or quite the overall clarity.  A DBT would be interesting to try.
A21 was disappointing with my setup.  Bass seemed thin and mids were too prominent as a result.
Adcom sounds nice too but midbass sounds a bit muddy.
