Industry Circles
NuPrime Audio
rustydoglim
IDA-8 Analog Output voltage?
gordon
6 Jan 2018, 08:59 pm »
Just noticed a bit of confusing info: my IDA-8 Analog outs are labelled Sub Out and the manual indicates an output voltage 3x a typical preamp out (meaning 6 volts vs 2v). Yet the specs on line show the output voltage to be 2v (a normal output I think?)
Can anyone help determine whether it’s 2 or 6v?
RafaPolit
Re: IDA-8 Analog Output voltage?
6 Jan 2018, 11:32 pm »
Gordon, some first or middle batches of IDA-8 had the 6v, yet latter ones use the 2v. I'll try and find the links discussing this. If your IDA-8 is more or less new, most likely you have a 2v one.
Best regards,
Rafa.
RafaPolit
Reply #2 on:
6 Jan 2018, 11:38 pm »
Here are two links discussing the issue:
http://www.audiocircle.com/index.php?topic=135837
http://www.audiocircle.com/index.php?topic=141610
gordon
Reply #3 on:
7 Jan 2018, 03:41 am »
Rafa, thank you for helping sort this out, very kind of you to take time to provide the links and explanations.
A bit of a crazy scenario! Any idea if the labelling on the rear panel was kept as “sub-out” through the voltage changes? And was the owner manual kept as 3x normal output?
I’m trying to determine whether my ida-8 is 6v or hopefully 2v.
rustydoglim
Facilitator
Reply #4 on:
19 Jan 2018, 08:30 pm »
The owner manual is outdated. The line out for IDA-8 is standard 2X gain.
RonN5
Reply #5 on:
31 Jan 2018, 03:22 pm »
Quote from: rustydoglim on 19 Jan 2018, 08:30 pm
When you say "standard 2x gain"...are you saying that the current IDA-8, one that would be sold today, is 2 volts or 4 volts at the sub output?
rustydoglim
Facilitator
Reply #6 on:
31 Jan 2018, 07:56 pm »
I just checked the spec on the website, it is 2V
http://www.nuprimeaudio.com/product/ida-8/
Industry Circles
NuPrime Audio
rustydoglim
