Just to put my "2 cents" in, the Dirty Weekends and the Omen Mk II are two different, though similar looking, speakers. Even with the addition of the clarity caps in the DWs, they are not the same. I owned a pair of DWs w/ clarity caps for almost a year, then I upgraded to the new Omen MK IIs (with the new drivers) and the difference is immediately noticeable. That being said, so is the price, so there's that to consider. The DWs with all available upgrades are fantastic speakers for slightly over $1K, so I am not denigrating it at all. I loved mine.To "meander" back to the actual topic of this thread, I had a Rotel RA-1570 that I ran through both the DWs and the Omens, but just couldn't find any love for that pairing. A Zu speaker owner suggested the Peachtree integrated amps and spoke very highly of that pairing. I picked up an old Peachtree Nova hybrid IA and it really was night and day. I've heard very good things about Rotel, but this pairing was just flat and lifeless. When I get my "big boy pants" I'm either going with one of those Primaluna EVO IAs or a Schiit Freya+ with some sort of equivalent power amp. I've heard a number of good things about the Freya+. Cheers!
I’ve paired my Omen DW’s with a Benchmark AHB2 and a pair of Odyssey Stratos monoblocks (not at the same time!).I’m probably spoiled, but I’m underwhelmed. Still looking for that magic combination. I’ve heard the Zu’s like tubes, so I may try that. I know that they can sound good, because I’ve heard it. I just haven’t made it happen in my own home. They are pretty, though (electric blue)!!
Stunning. Absolutely gorgeous! I actually bought them because they matched the room they are in!
Gene, I’d strongly recommend some toe-in. Looks like you’re firing them straight forward. I have found with this style of speaker (10” eminence handling midrange - both Zu and Tekton Lore) that having them fire just a bit behind the listener’s head is best. So that you can see the inside side baffle of the cabinet just slightly from the seating position.
I mean so that the point at which the direct paths of sound from each speaker converge (the point of the triangle between each speaker and listening position) is actually behind the listener’s head. In other words, the speakers are not pointing directly at the listener.
I found this set up offered improved bass. The longer feet ( carriage bolts ) in front with shorter feet in back also gave a tilt to the enclosure. With that back tilt the tweeters are aimed at one's ears.
