0 Members and 1 Guest are viewing this topic. Read 5121 times.
http://www.answers.com/mobile/Q/How_to_replace_tubes_in_a_tube_amp
WD-40
That's something I have handy, FullRangeMan! As a tube newb, I don't want to do any unnecessary harm. With a substantial amount of effort, I can probably get this tube pulled out far enough to fit a credit card or two between its base and the socket ... is it then safe to spray a little WD-40 directly into that gap?
WD40 is oiled and difficult to remove better dont use it.
Being the 6SN7 a bakelite base you should pull the tube by the base not by the glass.
Iam thinking that WD40 can collect dust in you sockets.
Do you think this tube was wrong position inserted?
Do you could raise the base of the tube with a slit screwdriver?
Thanks, but replacing tubes is literally the only part of this stuff that I actually have experience with. My question is, what do you do when the "just pull on the tube and it will come out" part doesn't happen? Given the amount of force I've used and the amount of time I've put into this, I'm not sure there's a way to get this tube out without resorting to using some sort of tools as levers to pry between the socket and tube base. It's *that* tight. What I'm hoping for is some sort of advice on getting it out while causing a minimal amount of damage.
If you inserted the JJ 6SN7 with the keyway properly oriented, this should not have happened! Typically, JJ uses thinner-than-standard contact pins on their tubes. This results in a looser than normal fit. My guess is that you may have forced the tube in incorrectly, jamming the keyway in, but out of its groove...Cheers,Geary
What a difference 34 minutes makes.
Now I'm confused. You suggested WD-40 but don't think I should use it?
Welcome to our world.Worse comes to worse, unsolder and replace the socket along with the tube. If it just won't budge, it may be easier this way. It may also be easier to separate them with the tube/socket more accessible. Obviously take a good crisp photo and/ or make a pictorial diagram so you can re-connect everything properly.
