How Delete All W10 Apps at Once
« on: 29 Dec 2017, 06:47 am »
In the Power Shell type:
Get-AppxPackage * * | Remove-AppxPackage
After it you will get :duh:
System Restore Error 0x80070005
Or:
Get-AppxPackage : Access is denied.
How Reinstall Full W10 Apps Package
« Reply #1 on: 29 Dec 2017, 07:17 pm »
Well after a mistake I deletad all the W10 apps.
To reinstall the full W10 apps package type in the Power Shell as adm:
Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
To see all the apps installed type in the Power Shell:
srb
Re: How Reinstall Full W10 Apps Package
« Reply #2 on: 29 Dec 2017, 08:11 pm »
The whole idea of uninstalling W10 apps was a solution looking for a problem that didn't exist.
lancruiser_
Re: How Delete All W10 Apps at Once
« Reply #3 on: 17 Oct 2025, 01:01 am »
One could use 2 solutions that are freeware.
https://www.revouninstaller.com/
https://www.oo-software.com/en/ooappbuster
Both use powershell scripts to perform their respective tasks.
