0 Members and 1 Guest are viewing this topic. Read 14635 times.
My reference DAC/Pre uses a fully balanced Slagleformer Analog volume control. My goal with this next gen DAC/pre will be to exceed the sound quality of the Slagleformer’s, with a 64 bit floating point “DSD wide” digital volume control. Price in lots of 20 will be $5000 each.
Mike,Congrats on having your own circle! I'm guessing you are going to offer an updated streamer/server at some point as well? So that would be a complete 3-chassis solution when combined with your dac/pre and amplifier?Also is everything going to be upsampled to dsd256 or dsd512 this time around? Personally as long as it sounds good I don't really care and it could probably be updated with a different module in the future anyways (?). If your dac is better or as good as the T+A Dac 8 dsd I'll be happy and in any case it is going to be night and day when compared to my current oppo 105 and its tidal app or the modded SBT I still own!! Keep up the excellent work and have a great weekend!
Thanks!Actually there won’t be any need for a standalone streamer anymore. Because it will have a built in Ravenna Audio over IP input. No more USB. Just like my Purestream DAC it will run at 11.289Mhz DSD only. By running at 11.289Mhz only, this allows us to use lower jitter clocks than are possible to use if you want to support DSD 512, and at the same time achieve lower out of band noise than any DSD 512 capable DAC like the T+A DAC 8 DSD. Because that DAC also needs to support all of the other DSD rates, they must set their analog filter at a lower frequency. This results in higher out of band noise at 512, than my DAC has at 256. With the benefit of much lower jitter clocks.
Our reference when designing this unit will be the MSB Select DAC 2. If my client who owns one doesnt think it’s just as good or better with his Focal Utopia headphones connected direct to the analog outputs, the Puremusic will never be released as a group buy unit for $5000.
And consequently the server you used to offer is still up to the task and the NUC is perfectly up to date I assume? It's still going to be compatibe with Daphile, Roon+HQ Player and offer the same airplay emulator? Now that's what I call reassuring! Go hard or go home!!
Ok so you're not planning on updating the superserve for now. What about the airplay emulator? Is it going to be integrated to your Dac somehow?
Roon now has their upsampling dialed in to sound much better than HQplayer, while using 1/4 the CPU power.
Mike, i hate hqp - its awkward and unnecessarily fiddly. Remember; I had to get you to set it up!Having said that, It leaves Roon far behind sound quality wise, particularly when using convolution.
