PAP Quintet15
0 Members and 1 Guest are viewing this topic. Read 8820 times.
drhoon
Re: PAP Quintet15
« Reply #20 on: 23 May 2018, 01:16 pm »
With 6.8mH inducttor and 106uF cap we will get 187Hz cut.
How can I calculate this ?
matevana
Re: PAP Quintet15
« Reply #21 on: 23 May 2018, 06:21 pm »
I'm not jealous at all.
Really.
 :D
Re: PAP Quintet15
« Reply #22 on: 23 May 2018, 09:54 pm »
http://shopping.na3.netsuite.com/s.nl/it.I/id.8/c.650256/n.1/.f
Avoid iron core inductors they are bad sound,
they are first order/6dB but are cheap.
« Last Edit: 10 Nov 2018, 01:15 am by FullRangeMan »
shadowlight
Re: PAP Quintet15
« Reply #23 on: 10 Nov 2018, 01:02 am »
@happyrabit / Dwight
How far from the back wall do you have the speakers from the rear wall and how large (dimension would be helpful) is your room.
happyrabbit
Re: PAP Quintet15
« Reply #24 on: 10 Nov 2018, 02:19 am »
See attached (moved recently).  It’s a big space including dinning room plus kitchen.  ~4’  to the back wall.
Dwight
shadowlight
Re: PAP Quintet15
« Reply #25 on: 10 Nov 2018, 02:50 am »
Thx.  Taking a guess on the dimensions, but the width is most likely around 15 to 16', with the length closer to 25 to 30' and ceiling around 9 or higher.
happyrabbit
Re: PAP Quintet15
« Reply #26 on: 10 Nov 2018, 03:04 am »
One more pic.  Pretty close on the dimensions  :green:
PDR
  • May the best man win
Re: PAP Quintet15
« Reply #27 on: 10 Nov 2018, 03:09 am »
Nice set up.
You should really consider treatments.....
That room looks.....lively.
happyrabbit
Re: PAP Quintet15
« Reply #28 on: 10 Nov 2018, 03:16 am »
my tv watching speakers  :popcorn:
« Last Edit: 10 Nov 2018, 04:13 pm by happyrabbit »
happyrabbit
Re: PAP Quintet15
« Reply #29 on: 10 Nov 2018, 05:57 am »
repeat
