SHATTERED GLASS … No more tubes – Class D all the way baby and loving it!
0 Members and 1 Guest are viewing this topic. Read 15762 times.
smargo
In short, these amps are so good I’m not the slightest bit curious about anything else out there. If you are a tube aficionado like I was, you’d do well to check these out. Chances are you’ll like them a lot more than your beloved tube amp.  :wink:
the magic that the stereo maraschino has - is everything i wished i could hear from the various iterations of tube amplifiers that i have had throughout the years - it may not have the last bit of resolution and slam- but who cares - magic and musicality take precedence over everything else
Shear Bliss VMPS
I too run and love the Class D sound that Tommy and Digital Amplifier Company produce, having a Classic Cherry. But I have begun switching over to a tube amp in the cold winter months that S.E. Michigan has. Tube amps need care and planning, and tube choice very important to get the best sound from them!!
Plus four KT-120s emit enough heat to take the chill from my cave, as my heat vent somewhat cut off from the room. And room heaters make too much noise so I make do for 5 months or so. BUT of course once the weather breaks its like Christmas in July ... or April as the Cherry once again takes its rightful place ruling the roost! Its like getting a new Cherry amp every Spring, and that in itself warms my heart.
Wind Chaser
  - it may not have the last bit of resolution and slam - but who cares - magic and musicality take precedence over everything else.
I can't imagine more resolution or slam being a good thing. There comes a point where enough is enough and anything more is obtrusive and exaggeration.
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
AmpDesigner333
These threads on Audio Circle also mention tubes vs Cherry....
"The Honeymoon Ain't Over Yet..."
https://www.audiocircle.com/index.php?topic=156310.0
"Does the Cherry Amp sound like tubes ????"
https://www.audiocircle.com/index.php?topic=107837.0
"Stereo Maraschino (King Version)"
https://www.audiocircle.com/index.php?topic=149310.0
"Switching from tubes to Cherry -- benefits"
https://www.audiocircle.com/index.php?topic=166206.0
