Optical to coax S/PDIF converter recommendation... ???
jriggy
I’d like to use my ol’ appleTV w/ optical output to burn-in some hours on a new DAC with coax S/PDIF input (spare my CDP from spinning for a week strait), so I’m looking for a good converter to do this with... want a good one but would love a quick Amazon Prime order to get a movin’.
Or does it even matter here? Cheap conversion is a cheap conversion.
jriggy
Re: Optical to coax S/PDIF converter recommendation... ???
« Reply #2 on: 7 Dec 2017, 01:26 am »
Yeah, that’s probably the one. But if there was a far better one buried on web somewhere, I could be tempted.
jriggy
« Reply #4 on: 7 Dec 2017, 02:40 am »
Oh yeah! I forgot about the iPurifier. I checked em out earlier in the year for something else. Thanks for the reminder, rodge.
rodge827
« Reply #5 on: 7 Dec 2017, 04:14 am »
Ur welcome.  :thumb:
A_shah
« Reply #6 on: 7 Dec 2017, 06:49 am »
Any recommendations for a good Quality Toslink cables , and should they be glass or plastic Benchmark audio sells Toslink cables for about $ 50.00 and than Lifatac has glass Toslink cables , would appreciate a feed back from AC members
Asghar
rodge827
« Reply #7 on: 7 Dec 2017, 12:16 pm »
Asghar
Glass is better than plastic...Wireworld and Lifatec have worked well for me.
http://www.wireworldcable.com/tablet/hi-res-digital-audio-cables.html
http://www.lifatec.com/toslink2.html
bacobits1
« Reply #8 on: 7 Dec 2017, 12:23 pm »
I have a Lifatec glass here and it is very good.
A_shah
« Reply #9 on: 8 Dec 2017, 05:51 am »
@rodge827 @ bacobits,
thank you , just ordered two Lifatec glass toslinks one  with toslink mini plug to work with my apple Imac mini and toslink to toslink to work with my PS Audio Directstream DAC
Asghar
