FS - Nikon AF-S NIKKOR 70-200mm f/4G ED VR Lens *SOLD*
0 Members and 1 Guest are viewing this topic. Read 1912 times.
rklein
  • My finest audio piece ever!!
I am selling my AF-S NIKKOR 70-200mm f/4G ED VR Lens.  This lens is in minty shape and includes the lens hood and bag, front & real caps.  I also have the original packaging.
THIS LENS HAS BEEN SOLD
Below is a stock picture of the lens.  I will try and post pictures of the actual item later today.
The AF-S NIKKOR 70-200mm f/4G ED VR Lens from Nikon strikes an ideal balance between exceptional optics, advanced lens technologies, compact size and a range of popular focal lengths. Designed for full-frame Nikon FX-format cameras, this G-series lens is also compatible with Nikon's cropped DX-format cameras. When attached to a cropped sensor camera, the 35mm equivalent focal length is 105-300mm.  Its constant maximum f/4 aperture provides consistency throughout the zoom range and Vibration Reduction technology offers 4-stops of compensation against the blur caused by camera movement, enabling handheld shooting in low-light conditions.
Nikon's exclusive Silent Wave Motor (SWM) provides fast, accurate and quiet autofocus and seamless manual focus override gives you precise focus control even in AF mode.  The Internal Focus design of this G-series lens means the length of the lens remains constant as you focus. Minimum focus distance is 3.3'  Three Extra-low Dispersion (ED) elements minimize chromatic aberration - even at the widest aperture - and enhance sharpness. Nano Crystal Coat prevents internal lens reflections, ghosting, and flare. This compact zoom lens offers a very practical set of focal lengths in a lightweight, easy-to-carry form.
DX-Format (35mm Equivalent): 105-300mm
Though it is a full-frame, FX-format lens, the 70-200mm f/4G is compatible with Nikon's cropped DX-format sensors. With a crop factor of 1.5x, DX-format sensor cameras turn the 70-200mm focal length of this lens into the 35mm equivalent of a 105-300mm lens, adding greater telephoto zoom capabilities on the smaller sized sensor.
Thanks for looking.
Randy
« Last Edit: 8 Dec 2017, 05:47 am by rklein »
rklein
Re: FS - Nikon AF-S NIKKOR 70-200mm f/4G ED VR Lens
« Reply #1 on: 3 Dec 2017, 04:30 pm »
My apologies for not uploading these pictures earlier...
This lens has been sold.
« Last Edit: 8 Dec 2017, 05:48 am by rklein »
