ART Tube MP preamp, it's cheap but is it cheerful?
Doublej
« on: 29 Nov 2017, 01:06 am »
It's cheap, real cheap.
Has anyone listened to one? If so what did you think of it?
https://www.bhphotovideo.com/c/product/130518-REG/ART_TUBE_MP_Tube_MP_Preamplifier.html
jkelly
Re: ART Tube MP preamp, it's cheap but is it cheerful?
« Reply #1 on: 29 Nov 2017, 02:15 am »
As a mic preamp for recording?
Doublej
« Reply #2 on: 29 Nov 2017, 03:12 am »
Could it be used to drive a pair of active monitors such as the JBL LSR305s with the source being a computer?
« Reply #3 on: 29 Nov 2017, 03:28 am »
Mics have low signal voltage hence preamps have lots of gain. You will have to risk with inputs sensitibity or ask the shop ''experts'' that they claim have.
Gain Range    70dB (XLR to XLR typical)
JDUBS
« Reply #4 on: 29 Nov 2017, 03:33 am »
It says its single-channel, so.......
-Jim
Doublej
« Reply #5 on: 29 Nov 2017, 11:48 am »
So that wouldn't work. I guess I need to learn to read. I'll dig my Chase out of the closet and see if it still works.
