0 Members and 1 Guest are viewing this topic. Read 8300 times.
I would not buy the Schiit Vidar yet, a product that I have followed these days. There have been some complaints about the first series and some speaker cables (for capacitance). Presumably they will solve it soon.My other option was: Icepower 1200AS amp. Class D like you've neverhttp://www.audiocircle.com/index.php?topic=153645.0
Only $499 !!!!!!!!!!!!!!!!!!!!!NuForce STA200 160-watt Stereo Power-Amplifier, GOLMUND Swiss-design!https://www.amazon.com/NuForce-STA200-160-watt-Power-Amplifier-Swiss-design/dp/B01552AKCU[IMG Inside amp] Nuforce STA200 vs JOB 225http://www.audiocircle.com/index.php?topic=151000.msg1615240#msg1615240
mtrot, you may not have been able to get the best from your Krell yet, it is a beast, excellent transient response and power, if you got an integrated, you'd be going backward, unless spending 5 figures to get close in the power amp section. You, indeed, just need a preamp. Man, if you can find a used KRC-3 you'd have a killer set up. If not, a 280p may do alright and be in your budget used. Any decent balanced circuit preamp would work, further chlices used, Bryston or Coda.I am not a fan of Rotel, I personally don't like the sound, and, anyone familiar and honest would tell you preamps was never their strong point. I'd prefer using an Emotiva and saving the money.Here's a good choice for preamp. https://wyred4sound.com/products/pre-amps/stp-se
