Thorens TD-124 Custom Aluminum Top Platter
0 Members and 1 Guest are viewing this topic. Read 3911 times.
Jeff V.
« on: 14 Nov 2017, 03:37 pm »
Custom made aluminum top platter for the Thorens TD-124. Replaces the thin, often warped top platter used on the TD-124. This top platter is a little taller than the original with a thicker top plate. It is stronger and heavier than the Thorens platter. Weight is over 1100 grams compared to the original at 450 grams. Height is 21mm. Clutch is still functional. I find the added mass improves the sound of the TD-124 compared to an original top platter. This version allows use of turntable mats of your choice or you can use no mat with a record stabilizer.  Price $435
Price includes free shipping in the US. Thanks for your interest
AlTran
Re: Thorens TD-124 Custom Aluminum Top Platter
« Reply #1 on: 14 Nov 2017, 10:24 pm »
I first bought one of these from Jeff & I the results is "a wow factor" which makes the bass tighter, more refine details & the mid is clean without any fuzziness, I highly recommended to anyone who has a TD124. Jeff also has 2 versions of the bearing, 1 is a modified from the stock & the other is a completely new machine piece that is almost double the size of the stock bearing, which I bought as well which results in a huge transformation of my TD124. I'm willing to offer audition for anyone locally in Southern California.
Jeff V.
« Reply #2 on: 15 Nov 2017, 12:10 am »
Thanks for the kind words Allen.  The top platter currently for sale isn't as tall as yours and doesn't require a new spindle like the thick one you have.  I'm glad you are pleased with the results!
Jeff
Jeff V.
« Reply #3 on: 18 Nov 2017, 12:34 pm »
I also have a custom top platter that uses the 124's original mat & 45 adaptor.  This top platter is also much better than the original.  Taller, thicker and stronger.  Also looks and sounds better than the Thorens thin top platter.  Does not include the adaptor or mat.
WntrMute2
« Reply #4 on: 15 Jun 2018, 12:08 pm »
Are these still available?
machsw
« Reply #5 on: 9 Jun 2025, 03:16 am »
Hi, are still available? How can I contact you
beeah
« Reply #6 on: 9 Jun 2025, 11:34 pm »
I am not the original poster, but since you asked, I feel obliged to answer your question.
A private message (PM) is, imo, ALWAYS the best way to inquire about a Trading Post ad. This is not possible for very new or inactive accounts, but neither of those limitations appear to apply to you.
Another universal truth is that replying to a 7 year old post in ANY forum will, in the best case, result in no reply. Rather, it is more likely that some crotchety curmudgeon with too much time on their hands will call you out for doing so.
I hope this helps. Best of luck in your search.
