Mid suggestion for OB application
0 Members and 1 Guest are viewing this topic. Read 5269 times.
jimbones
Re: Mid suggestion for OB application
« Reply #20 on: 4 Nov 2017, 06:03 am »
Making sense now, thanks Tyson for the explanation. So although i prefer to not use my minidsp, i will bring it out to see just how much boost i need and if it works.then ill consider my options.
So I trotted out the minidsp and added enough boost to bring the frequency flat. It sounded like doo doo. I backed off on the boost. I lowered it to 6db of boost at 185hz. sounds ok but I need to spend some time with it.
JohnR
« Reply #21 on: 4 Nov 2017, 06:14 am »
You were probably clipping the DSP.
Are you doing measurement sweeps? It might be more helpful if you posted them.
jimbones
« Reply #22 on: 4 Nov 2017, 02:30 pm »
I did sine sweeps and noise. results essentially the same. When I flattened the curve it sounded too thick. I think I need to make more measurements some in the listening position. These were made approx 1m from baffle. Dan did say I should back up to listening position.
