4B3 buzzing from one channel
0 Members and 1 Guest are viewing this topic. Read 1381 times.
jimangie1973
« on: 29 Oct 2017, 01:49 pm »
Hello,
I just purchased a 4B cubed amp.  It sounds awesome but has one issue that is annoying me.  I'm getting a low level buzz from the left speaker.  This buzz is audible from up to about 3 feet from the tweeter.  My speakers are about 88 dB sensitivity.  I've sent a message to Bryston and am waiting for reply Monday.
I've done a bunch of troubleshooting and the results are as follows:
  • buzz occurs for both balanced and unbalanced
    buzz increases/decreases with 23dB/29dB gain setting
    cheater plugs on amp and/or preamp did not help
    with no interconnects or interconnects and no preamp, no buzz
    with preamp only, and no inputs to it, buzz
    with passive stereo volume control (no inputs to it), buzz
    with unbalanced inputs shorted, no buzz
    with unbalanced inputs shorted, and LR shorted to each other, buzz
So based on this, anytime the LR inputs share a common ground, the buzz appears.  I really want to solve this problem because the amp really sounds great.  I also have both a 3Bsst and 4Bsst which are dead quiet so it really should be fixable.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 4B3 buzzing from one channel
« Reply #1 on: 29 Oct 2017, 03:49 pm »
Hello,
Hi JIm
Sorry for the trouble - did you send an email to Mike?
[email protected]?
james
jimangie1973
« Reply #2 on: 29 Oct 2017, 03:56 pm »
Hi James,
Thanks for the reply.  I sent the email to Bryston using the messaging on the website.  I selected the technical support option.
-Jim
« Reply #3 on: 29 Oct 2017, 04:10 pm »
Hi James,
-Jim
Ok I will copy this and send to Mike directly.
james
jimangie1973
« Reply #4 on: 29 Oct 2017, 04:27 pm »
Thanks a lot!
jimangie1973
« Reply #5 on: 26 Nov 2017, 07:50 am »
I got my replacement 4B3 today and am pleased to say the buzz is gone!  Complete black background with the same wonderful sound as the first unit.  Bass is super solid with very transparent mids.  Treble is very refined with no harshness whatsoever.
Thanks a bunch to Bryston for their fantastic product support.
Finally, the cubed units look very impressive in person.  I was initially not a fan of the look but now I really like it.
