0 Members and 1 Guest are viewing this topic. Read 15720 times.
Just pulled the trigger on a Benchmark DAC3 L. Should arrive next Wednesday. I currently use an Eastern Electric mini max with Dexa op amps and no Tube. Can't wait. Will give impressions next week
Whilst I do heed the advice from wind chaser on run in time, I feel compelled to comment on my initial thoughts after receiving it today............... The Benchmark DAC3L sounds stunning and kicks my older DAC to the curb big time. Lower noise, much better headroom and much more clarity and soundstage. Benchmark has a 30 day return policy and in my mind it could be 30 minutes. Sound right out of the box is stunning and a huge improvement over my old DAC which has been modded with Dexa op amps. Will report more later but could not be more pleased with it. Give the DAC3L a look and a listen. My wife even thought it was a significant improvement which is unusual for her to comment. Best audio purchase I have made in a long time. Heard it first at RMAF 2017
I believe the headphone amp is the only difference. There is another model DX, I believe, and I think it has a headphone amp as well. Give Benchmark a call, they were very helpful on options etc of the models. BTW the DAC3L manual is also the manual for the DAC3 HGC so I think other features are the same
A follow up on my new Benchmark DAC3 L.............. After a couple of weeks in service I can't think of a better addition to my system. Very well built and it adds so much compared to my old DAC. My wife describes it as "you can now hear so many layers in the music that we did not hear before". The floor noise is extremely low if there at all, great dynamic range. The improvement sounds just as substantial on my old red book material as it does on hires music. You can look at my system in my profile for associated gear. Wide sound stage, loads of detail and very musical (believe this is due to the 2nd and 3rd harmonic special circuit), not clinical. I could not be more pleased. I have not tried it yet as a DAC/pre just as a DAC. Next up will be to remove my Nuforce P9 pre from the loop and see how it performs as a DAC/pre. I looked long and hard for a new DAC and landed a jewel. Strongly suggest you give it a try (30 day return if not satisfied but I mentioned earlier it only took 30 min to know it was a keeper). BTW the Benchmark folks on the phone are very knowledgeable, customer oriented and helpful. 5 yr warranty if you register the DAC on-line with Benchmark.
Nice addition Peter!Let us know how the new Dac3 compares to the Cambridge 851 - that is a comparison I would be interested to hear as the 851 is no slouch!
A follow up on my new Benchmark DAC3 L.............. After a couple of weeks in service I can't think of a better addition to my system. Very well built and it adds so much compared to my old DAC. My wife describes it as "you can now hear so many layers in the music that we did not hear before". The floor noise is extremely low if there at all, great dynamic range. The improvement sounds just as substantial on my old red book material as it does on hires music. Wide sound stage, loads of detail and very musical ... not clinical. I could not be more pleased. I have not tried it yet as a DAC/pre just as a DAC.
Wind Chaser....... No thunder stolen and I'm glad you are enjoying the DAC10!!!!Peter, I use RCA from the DAC3 L to my preamp. Also something I learned after reading the manual for the DAC3 if you're not using it as a preamp as well, press and Hold the mute button on the remote, the red light on the unit will flash and the DAC volume knob will move and reset itself to about the 3 o'clock position or 2 v output, Benchmark said to do this if you use a preamp or HT pass thru. I called Benchmark to ask what position I should have the DAC volume knob in as I was playing with the DAC volume and my pre volume. Now that it is set using the remote I only use the preamp volume for control. I plan on switching to use as a preamp as well after Thanksgiving when I will have a chance to do some critical listening. Enjoy your new toy!!!!
Peter, good idea to start a Benchmark DAC3 thread. We can also sent a link to Benchmark as well. I'll let you know how the preamp connection goes in a couple of weeks. Enjoy your new DAC and I hope you like it a much as I do mine. BTW have a great Thanksgiving and remember to be thankful for all of your blessings including a killer DAC
http://www.musicalparadise.ca/store/index.php? Pick your DAC chip.
