0 Members and 1 Guest are viewing this topic. Read 8168 times.
I just bought this (see link) from Ali Express, I got one for about 40 bucks Canadian. I bought it to run HDMI from my Laptop in order to listen to Blue Ray Images of Surround Audio. It can be run in 2 Channel mode as well as 5.1 as well as Pass through only. It works at decoding the audio signal but so far it has a WHOOSH sound constantly when sound is passing through it. I have fiddled with setting etc but it still is not usable. Dont buy this one, I am not happy with it at all, but maybe look for something like this it.https://www.aliexpress.com/store/product/HDMI-Digital-Audio-Decoder-HDMI-to-HDMI-VGA-SPDIF-5-1-Surround-Sound-Converter-Adapter-Singapore/607905_2053367090.html
Thanks for all the input. I did not know to look in the source menu to change the output. I do not care about sound quality for the few movies I watch or TV shows recorded from my antenna. I do care about the quality of my music so the 2-channel components will be selected carefully. I am only going to have two channel so other formats will have to be down-mixed at some point. Optical out from a TV may not be all that useful even if it is possible as a pass-through. I would need an integrated unit that has DAC functions and an optical input. That limits my choices although one integrated I am considering would work. My new home has an HDMI port low on the TV wall and another one mounted higher to be behind a wall-mounted TV. They are connected. There is also a power outlet there. That hides those two cables but for some strange reason the coax outlet is only mounted low on the wall so that cable would not be hidden. I don't know why they only did half the job. I guess if they put it high someone would be upset if they did not want to mount their TV. I would like to do all my HDMI connecting at the equipment rack and use only one hidden HDMI connection to the TV.
Onkyo and Pioneer Elite have 2 channel receivers with HDMI inputs
Doublej, I have not checked Onkyo yet but I did look at Pioneer Elite after you suggested it. I cannot find 2-channel models with HDMI. Do you know model numbers or have a link?fredgarvin, I have more sources to connect than the TV has inputs. In addition, I want to use the single, hidden in the wall HDMI line.
https://www.pioneerelectronics.com/PUSA/Home/2-Channel+Components/SX-S30
Atlona has a few products that may work for you.https://atlona.com/product/at-uhd-sw-51/I have a 4 way switcher that I use to send the PCM stereo data to my NuPrime IDA-16. The product I have is discontinued but they have a new version that may work for you. https://atlona.com/product/at-hd4-v41/
