Can anyone Identify the speakers system used here
0 Members and 1 Guest are viewing this topic. Read 913 times.
torro
« on: 25 Sep 2017, 02:55 pm »
I have just moved into my house and I cannot identify the speaker system that they previously had. I just have got holes in the walls now and would like to replace with the same or similar speakers fittings. Dont really want to leave holes in the wall.
cAN anyone identify these speakers, please?
cheers,
Torro
Re: Can anyone Identify the speakers system used here
« Reply #1 on: 25 Sep 2017, 05:01 pm »
cheers,
Torro
On these photos I see there is a plate w/the brand name.
Probable a UK brand we dont know.
wiggindude
« Reply #2 on: 27 Sep 2017, 08:04 pm »
You can always use those Bose Acoustimass system.
asliarun
« Reply #3 on: 28 Sep 2017, 04:57 am »
The original speaker should not really matter. As long as the speaker wires still end at the holes in the wall, you should be able to install any other speaker. If it has a proprietary connector, it smells a lot like the shenanigans that Bose pulls. But you could still rip off the connector and install generic speaker connectors so you could still install your own speaker system with the existing wiring. Thankfully Bose hasn't yet invented patented wiring that only works with Bose speakers. At least to my knowledge.
Blackmore
« Reply #4 on: 28 Sep 2017, 01:29 pm »
They look a bit like these KEF: E305BL
http://www.ebay.com/itm/like/192293628184
Hope that helps
