0 Members and 3 Guests are viewing this topic. Read 386281 times.
I've picked up a used Topping D50 that should arrive in a week or so. Anyone used a phone external battery to drive something like this? Any disadvantages?
I bet the difference between the D30 and E30 in SQ would end up being an exercise in hair splitting. The E30 display is a great feature and I've learned to appreciate it with the DX3 Pro.
I'll let you know tomorrow, I finally found mine and it's charging up now. From everyone reviewing the E30, which has the same power set up as the D50, the order of preference was laptop the worst, phone charger wall wart better, power bank much better, dedicated PS like the iFi wall wart the best. I have a phone charger on it now.
They sound very different in my system. D50 is typical sabre sound without the mid high bump. E30 sounds more similar to my D90 MQA but less of everything. Basically, E30 is smoother but could be considered more boring than the D50.
They are different beast for sure, but Leti was referring to the power circuitry. I'm eager to hear what he has to say about using a battery.
I cannot seem to remember the dac that had built in battery that you could hook up to phone for portable use. Anyone remember the name?
I believe that was the Topping NX4...
Well, to answer the question if you can power a Topping 50 dac with a phone external battery, YES. It works fine.
Promises, promises.
So I might be interested in replacing my bel canto 1.7 of roughly 9 years. I don’t stream though. I ve been looking at the Musical paradise, but I’m not sure I wanna pony up 2k right now. Which topping might work, or are there others that rival the topping?
Yep, running late as usual.So the main difference between batteries and a wall wart were... not much. Seriously don't think I could pick one out blind.
