0 Members and 1 Guest are viewing this topic. Read 2686 times.
..... the new space could be as large as 11'x21.5' with a jut out of 4'x13' for 15' in width for 13' of the room length.
I'm a little confused. Is the jut-out 4' H x 13' W with a 15 inch depth?
Most folks will probably chime in with a blanket "bigger is always better".At a glance, I'd guess that the extra depth would give your open baffle speakers more space behind, which seems to generally be a good thing.Have you checked out any of the online room calculators to see where (based on proposed room dimensions) your advantages and or challenges might be compared to your existing room?I have not, this idea has just started percolating New construction gives you a chance to go all in on treatment, sound isolation, and power/data management at the lowest long-term cost of entry.This may sound like a silly question, but I'm presuming based on your current room/setup that you listen alone? Is this a hobby that more people in the family/household might enjoy? Would the proposed new room give you space to add a few more seats to share the music with?This is part of what is being considered, my son and I enjoy listening together.srb, if I'm reading Ed's post correctly, it means he would end up with a room that would start as 15' wide for 13 feet of length, then would narrow to 11' wide for the last 8.5' (21.5' total length). yes, this is correct
I am considering framing in a part of a basement garage to gain a larger listening space. My current space is a 10.5'x12.5'x8', the new space could be as large as 11'x21.5' with a jut out of 4'x13' for 15' in width for 13' of the room length. Ceiling is 8'.What are your thoughts, would this size space be a noticeable improvement over the current room?Opinions welcome.Best,Ed
