0 Members and 1 Guest are viewing this topic. Read 19458 times.
richidoo, The reasoning is sound, experience tells otherwise, regulated supplies are not the best sounding on field coils.
You're right, if you're using power supplies from the 1930's
Seems too good, I would like it if these promises are fulfilled since it be controlled by hand, not automatic or pre regulated.
If you guys think regulated supply is the way to go, go ahead!Several few field coil speakers manufacturers has discovered otherwise, I have nothing more to contribute.
OKHere's another questionHas anyone ever encountered a field coil midrange (8") incorporated into a 3 way open baffle using alnico permanent magnet drivers for the highs and lows?
dear shooter, please tell me what power suplly i must make, or buy to power supravox 215-2000EXC speakers ?i know what car battery is best option, but constant rechargint is sooo anyoing. linear power supply , lets say 12v capable of 10Amps. for me would be sooo good. please give some links or just more specific info, not just this is good this is not. be more specific, thanks,:)
Really 10 amps needed to drive a Supravox field coil 215?I do want to build my own Supravox field-coil speakers but I cannot get the proper info about the required current at 12V per driver. If anyone can help...Thanks!😆 Gianluca
