Bryston BP17 Cubed preamplifier
0 Members and 1 Guest are viewing this topic. Read 85358 times.
Stefan_DR3
Re: Bryston BP17 Cubed preamplifier
« Reply #220 on: 4 Aug 2019, 10:15 pm »
Hi George
Working on putting the first prototype together so I can audition it.
james
Interesting news (BP18) James!
Can the muting circuit be revisited for the new model so balanced XLR users don't get that pop on mute/unmute?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #221 on: 5 Aug 2019, 12:30 am »
Hi
I have the BP17 in one of my setups and no pop?
james
Stefan_DR3
« Reply #222 on: 5 Aug 2019, 10:54 pm »
Hi
james
I wrote about it here:
https://www.audiocircle.com/index.php?topic=151889.msg1719028#msg1719028
Maybe there's some variance between units but others chimed in and the unit at my dealer (Audioshop Kanata) does it too.
Stefan
« Reply #223 on: 5 Aug 2019, 11:49 pm »
HI Stefan
OK I will look into it - what amplifier are you using?
james
gberger
  • Check 6
« Reply #224 on: 5 Aug 2019, 11:58 pm »
Hi James,
What DAC capabilities are planned for the "BP!8" ?
George
Stefan_DR3
« Reply #225 on: 6 Aug 2019, 03:57 am »
HI Stefan
james
Bryston 7B2  :)
« Reply #226 on: 6 Aug 2019, 10:32 am »
Hi James,
George
Hi George
Same as the BDA-3 DAC.
james
gberger
  • Check 6
« Reply #227 on: 6 Aug 2019, 06:32 pm »
Hi James,
Thank You!
I'll really be interested in how the "BP18"will fit into a streaming setup.
George
rmurray
« Reply #228 on: 7 Aug 2019, 02:16 pm »
 I assume there will be a polarity reverse feature on this new model ? :thumb:
gene9p
« Reply #229 on: 8 Aug 2019, 12:23 am »
Ron D
« Reply #230 on: 8 Aug 2019, 12:33 am »
I would venture it is as I recognize the number. I'm not a regular poster here so take my input as you will...
As it's on Audiogon it would be in $US, never seen that unit sell that low in my native Canada for our Canuck bucks
gene9p
« Reply #231 on: 8 Aug 2019, 01:25 pm »
exactly.....it's an extremely low price..well it's gone or sold now... :o
dminches
« Reply #233 on: 18 Nov 2020, 12:56 pm »
With this preamp can one use the variable balanced output to connect to an amp and also use the variable single-ended output for a subwoofer?  That is, are they both active?
« Reply #234 on: 18 Nov 2020, 01:55 pm »
Hi
Yes both are active.
james
dminches
« Reply #235 on: 18 Nov 2020, 05:03 pm »
Hi
james
Do the unbalanced outputs produce the same level of output at the balanced ones or are they 6 dB or so lower?
« Reply #236 on: 18 Nov 2020, 05:26 pm »
Same but adjust the levels at the subwoofer.
james
Jozsef
« Reply #237 on: 18 Nov 2020, 11:12 pm »
This is good to know and rather timely for me. Even though a high pass filter on smallish main speakers is beneficial when using a subwoofer, I was troubled by the idea of putting everything through a rather old Velodyne ULD-18 controller. Using my Bryston speakers full range with the sub crossover set to the correct frequency solves the problem.
mr_bill
« Reply #238 on: 13 Dec 2020, 04:25 am »
James,
Is the optional dac module for the BP17 cubed preamp most similar to the BDA3 dac?
I was reading the Stereophile follow up review on the modules and that’s what I took from the article.
Bill
« Reply #239 on: 14 Dec 2020, 10:23 pm »
Hi Bill,
Yes it is the AKM DAC
james
