Bi Amping
0 Members and 1 Guest are viewing this topic. Read 5097 times.
Gordy
Bi Amping
« Reply #20 on: 13 Dec 2004, 10:15 pm »
Thank you Jens and Andy!
It certainly wasn't my idea though, it was suggested by George Short, the designer of my North Creek speakers and sub.   It was intended as a 80 hz (?, been a couple of yrs.) x-over to my monitors, the other tail of the 'Y' adaptor would feed a powered sub.  I though I could use this as a feed to the AKSA, to save it some work.  Perhaps a simular rig could be used as a low pass to feed a Carver switching amp to feed two nonpowered sub units?   What is the formula I would use to calc. the cap sizes?
Thanks again for your feedback :D
Gordy
AKSA
Bi Amping
« Reply #21 on: 13 Dec 2004, 11:30 pm »
Hi Gordy,
Formula is C (in uF) = 159000/Xc.f
Xc is impedance desired in ohms
f is frequency in Hertz.
Example:
Let's say you want your coupling cap to be 6dB down (that's half voltage) at 80 Hertz.  The input impedance of an AKSA is around 43K ohms, so the equation give us:
C = 159000/43000 x 80
This is 0.04622uF.
You'd likely go up to the nearest preferred value to further reduce LF phase shift, and this 0.047uF, or 47nF.
Recalculating for the preferred value gives us 78.6Hz, close enough.
This simple first order filter is flawed, however.  The Zin of the AKSA is not a constant 43K;  it varies very slightly with input amplitude because of the base admittance on the semiconductor, T1.  But this is likely only about 10%, so it's not all bad.  Furthermore, there will be considerable phase shift at the corner frequency, extending upwards to about 300Hz, which is significant.  The only way around this is to increase C1 to large levels, and the stock value is 0.47uF, ten times larger.  But for the frequencies at which you are using the amp, it's unlikely all this is too important, because it beats using an active filter, with all the attendant complexity, to secure just a first order function.
There is a swathe of math around filter design, something I don't fully grasp.  Others might know the fine detail;  but I can assure you that this will be around 6dB down at 80Hz, and 12dB down at 40Hz, and 18dB down at 20Hz.  This is useful attenuation, as it reduces out of band operation of the midbass driver.
Hugh
andyr
Bi Amping
« Reply #22 on: 14 Dec 2004, 12:29 am »
Quote from: AKSA
Hi Gordy,
Let's say you want your coupling cap to be 6dB down (that's half voltage) at 80 Hertz.  ...
Sorry Hugh but a series cap is a 1st order passive HP Butterworth filter and I believe the equation you quoted gives the 'customary' -3dB (70%) point ... not the -6dB (50%) point.
Quote from: AKSA
This simple first order filter is flawed, however. The Zin of the AKSA is not a constant 43K; it varies very slightly with input amplitude because of the base admittance on the semiconductor, T1. But this is likely only about 10%, so it's not all bad. Furthermore, there will be considerable phase shift at the corner frequency, extending upwards to about 300Hz, which is significant. The only way around this is to increase C1 to large levels, and the stock value is 0.47uF, ten times larger.  ...
Shirley, if you increase the C by 10, you reduce the resulting f by 10 ... so you get a 7.86Hz -3dB point ... which ain't much use to Gordy?
Now, I've heard many "experts" proclaim the so-called "advantages" of PLLCs over "conventional" PHLCs but no-one has ever mentioned potential changes in the amp's Zin before ... which, even though it might be only 10%, seems to me like a bad thing.
Do all ss power amps have this attribute?  Wot about toob amps?
Andy
Gordy
Bi Amping
« Reply #23 on: 14 Dec 2004, 02:09 am »
Thanks Hugh and Andy,
I thought I was following you there for a second :lol:   I may just try it anyway as I never learn anything unless it's the hard way!  Then I'll just go back to running them full range and bring the subs in from below...
Appreciate all the help :D
Gordy
Joules
Bi Amping
« Reply #24 on: 14 Dec 2004, 12:25 pm »
This is what I have been doing for a long time (at 130 Hz)- very clean, very inexpencive !! I still get a lot of bass in the mid bass driver tho. I supose one could cascade multible RC filter in series to get faster rolloffs.
I just wish LP was just as easy !!
Jens
Bi Amping
« Reply #25 on: 14 Dec 2004, 02:53 pm »
It is possible to help the low order roll-off you get with just a single cap by constructing your speakers in such a manner that the acoustic roll-off of the midrange coincides with the cap roll-off. Very efficient!
This is obviously difficult to do if you don't build your own speakers, but I thought I might offer this advice for those who do.
In my case, the line level cap will replace a capacitor bank in the speaker x-over of some 150 uF! Absolutely worthwhile. And it's possible to use very high quality caps because they are so small. Much cheaper than the passive x-over components.
Jens
Joules
Bi Amping
« Reply #26 on: 14 Dec 2004, 04:55 pm »
"In my case, the line level cap will replace a capacitor bank in the speaker x-over of some 150 uF! Absolutely worthwhile. And it's possible to use very high quality caps because they are so small. Much cheaper than the passive x-over components."
  EXACTLY !!!
Much cheaper than a Active x over too!
and cleaner sounding.
Jens
Bi Amping
« Reply #27 on: 14 Dec 2004, 11:26 pm »
Quote from: Joules
  EXACTLY !!!
No doubt about this!
But - what type of cap is best suited for this purpose? I would have gone for Black Gate, but since 15 nF (which is what I need) is not available, what type of cap should you use? I've had some luck with Wima MKS/MKT caps, which seem to work well for this application, but there might be better things out there.
Suggestions, guys?
Jens
kyrill
Bi Amping
« Reply #28 on: 15 Dec 2004, 10:02 pm »
Hi Jens
You can create a value by paralelling it. I am sure you know
Gordy
Bi Amping
« Reply #29 on: 15 Dec 2004, 10:54 pm »
Quote from: Joules
I found these at Parts Express, http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=266-252    and wonder what they are comprised of, worth pursuing?
Davey
Bi Amping
« Reply #30 on: 16 Dec 2004, 02:02 am »
Hope you fellas don't mind me butting into this thread.
Those Fmods are line-level passive crossovers implemented with internal RC combinations.  They're not insensitive to source and load resistance so the actual roll-offs and slopes may vary a bit from the advertised numbers.  In all cases you would need a source with fairly low output impedance.
Low-pass RC filters are harder to implement because there needs to be a resistor in series with the load.  This creates a voltage divider with the load so you get some insertion loss.  However, if the source impedance is low enough and the load impedance high enough the component values can be optimized to reduce the loss.
Here's a reference with some basic information:
http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
15nF is a standard capacitor value.  A good quality polypropylene capacitor can be sourced from folks like Digikey for less than a dollar.
Davey.
Joules
Bi Amping
« Reply #31 on: 16 Dec 2004, 11:58 am »
Marchand has a passive line level XO using ferrite coils as part of an LC filter. Any one have any experience with these? It all boils down to the sound of the ferrite coils vs. a high quality buffer amp in an active XO. Come to think of it the widly acclaimed ribbon tweeters use transformers to match imp. and no one seems to complain to much about them. The same could be said for the output Xformer in tube amps. And then there is the Beringer digital XO. Iwish I had the money and time to try them all.
