QINPU MINI Integrated Tube Amplifier - $125 plus shipping- Perfect for your desk
0 Members and 1 Guest are viewing this topic. Read 676 times.
apt_one
Surprising nice sounding mini amplifier with tube front end. Cost is $125 plus shipping, USA destinations only. Purchaser to add $18 USPS priority shipping charge.  You can  add a pair of white or black Realistic Minimus speakers for $50 plus add $10 shipping for a nice compact system. Buyer to add 3% is using paypal for payment, certified check and money orders accepted without surcharge. Email is [email protected]
Small size is the best word to describe this fine piece of tube transistor amplifier, it performs equally well in your bedroom or your living room , and produces enough power to push large speakers with harmonic, articulate musical sounds.
Small size Performs equally well in your bedroom or your living room, enough power to push big size speaker.
Aluminum Chassis served as heatsink, integrated amplifier with tube pre-amp.
 Specifications:
 Rated power: 2 x 2.5 W ( 8Ω RMS)
 Frequency Response: 50Hz-40kHz
 Input sensitivity: < 500mV
 THD (Total Harmonic Distortion): < 2% (1kHz)
 S/N Ratio: >85dB(A Weighted)
 Crosstalk Attenuation: >35dB
 Input Sensitivity: < 220mV
 Overloading Level: >10V
 Input Impedance: 20kΩ
Vacuum Tube: 6N3 x 2
 Power Supply:120V/60Hz USA
 Power consumption: 20W
 Net Weight: 1.4 kg
 Gross weight: 2 kg
 Product dimensions: (L x W x H)105mm x105mm x 110mm
Here are the Minimus 7 speakers that are an ideal match for the amp. If you want the speakers too- add $50 plus $10 shipping.
« Last Edit: 26 Jul 2017, 03:12 pm by apt_one »
