0 Members and 1 Guest are viewing this topic. Read 52266 times.
Where's a good place to get those OneACs? E-bay? Josh, don't you have 2 different models of OneACs? If so, what's the difference?p
Kevin,As you're a businessman with the associated legal (and moral) responsibilities, I certainly agree with your insistance on X2 rated caps. But as facilitator on this board, I'm well aware that folks are going to go ahead and use them anyway. Hence my insistance that they not be buried in a wall, and that they be mounted after a fuse.... To do otherwise on my part would be like insisting on abstinence rather than using a condom Have you evaluated the Wima MP3 X2 caps? I know that you use the Jon Risch reccomended Mallorys, but, IMO, find the Wimas prefferable. I've only found them at Mouser in minimum order quanties of 100+, and would love to find a retail source. (I always bypass these with a .1uf 15mm LS value MP3, if I'm using >0.1uf) ...
Josh- thanks for sharing all this great info. do you have your DIY unit on line yet, and what's the sonic results?
