Low Flow Shower Head recommendations?
dB Cooper
« on: 1 Jul 2017, 12:45 am »
Water bill here has been getting out of hand so have been thinking of putting one in and was looking for a recommendation for the cheapest decent-quality one I can find (Brand info etc). Thanks.
rocker9999
Re: Low Flow Shower Head recommendations?
« Reply #1 on: 1 Jul 2017, 01:00 am »
dB Cooper
« Reply #2 on: 1 Jul 2017, 01:04 am »
Why didn't I think of that...
Brettio
« Reply #3 on: 1 Jul 2017, 02:09 am »
In my experience I used more water trying to completely wash out shampoo, soap, etc. with a low flow head than I did in a quicker shower with a high flow head.
thunderbrick
  • I'm just not right!
« Reply #4 on: 1 Jul 2017, 04:53 am »
You sure you don't have a leaking toilet?  Hard to think a shower head could make the that kind of difference.
Do you have teenage daughters?  If so, the shower head is the least of your problems. :peek:
richidoo
« Reply #5 on: 1 Jul 2017, 10:01 am »
Lawn irrigation ramps up in May, bill comes in June.
avta
« Reply #6 on: 1 Jul 2017, 01:20 pm »
Speakman makes some fairly inexpensive shower heads.
walkern
« Reply #7 on: 1 Jul 2017, 02:06 pm »
I've been using Oxygenics shower heads for years (I live in So Cal where drought encourages conservation).  Unlike most low flow heads, these actually feel like they provide proper water pressure, so rinsing shampoo out of your hair goes quickly and easily.  They are cheap too (check Amazon... typically between $30 and $40 bucks).  I find the plastic white ones hold up as well as the shiny chrome ones and cost less.
Archguy
« Reply #8 on: 18 Jul 2017, 03:38 am »
I replaced all my shower heads with new Speakmans, after removing the flow restrictors of course.
They still make some good ones, though not their cheapest.
