Loving the new BDP-3!
unincognito
    • bryston.com
Re: Loving the new BDP-3!
« Reply #80 on: 14 Dec 2018, 04:02 pm »
cool, but the internal disk's space is limited to 2,5 units, isn't it?
Correct
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #81 on: 14 Dec 2018, 08:19 pm »
MEMO: To All Bryston Dealers and Distributors
SUBJECT: Bryston BDP-3 Player – German Review
December, 2018
Hi Folks,
We received an outstanding review on the Bryston BDP-3 Digital Player in a very prestigious German magazine.
For those that speak German I have the complete PDF (13 Meg) available if you want a copy -  ([email protected]).
Favourate Quotes in English:
•   No matter what type of signal we feed this Bryston player it puts out the needed characteristics. But at the same time it never sounds strained or muffled.
•   The Bryston BDP-3 does almost everything right. Mass storage, NAS, streaming services or internet radio - this player doesn't care about the source. It dominates all formats and delivers hi res in almost all situations.
•   Connectivity is well thought out and the use of technology and workmanship are first class.
•   If you are looking for a consistent digital source in order to listen to your music instead of your gear you'll find it at Bryston.
•   Not many source components are made in such a way to play back music so precisely. All digital options are provided and the player always extracts the very best of every bit.
•   A flexible source player with character and not with airs and graces.
« Last Edit: 14 Dec 2018, 10:08 pm by James Tanner »
Grant Hill
« Reply #82 on: 15 Dec 2018, 02:16 pm »
Correct
I think the largest available at that size is 3T maximum… if you want more you have to connect an external hard disk
zoom25
« Reply #83 on: 15 Dec 2018, 09:34 pm »
thanks Zoom what a great response!  My dealer from Calgary got me on to Roon using my iMac in another room.  From the modem I’m wired via Ethernet cord I said from the beginning hard wired always sounds better.  Wrong, boy I was wrong he was so right about wifi transferring.  I had a portable drive into my Pi first and it sounded great.  Roon wifi into the Pi is a step above that, now would a better sound card be sonically ahead vs the Pi?
I’ve never lagged even with MQA and HD transfers
If I had to speculate, I'd imagine the full sized BDPs to sound better than the Pi. The Pi has a coaxial, hdmi, usb, and optical output, whereas the full sized BDP have AES, coax, along with USB. I'm guessing the best output on the BDP-pi is the coax? On the full sized BDPs, AES has typically bettered coax and USB performance (until a BDP-3 + BDA-3 USB stack at least...as some like James claim). You could try a coax from BDP-pi against the coax from the full sized BDPs for a straight up comparison. However, AES is what's recommended by most users and James/Bryston (as noted in BDP(x) manuals) based on listening.
Regarding best playback method, it's what James cleverly said: MPD with internal drive (spinning over SSD).
That option is probably the cleanest and the least 'expensive' option overall when it comes to CPU and resource consumption. Again, this is only my speculation.
Regarding MPD vs. Roon, this is what Roon's CTO had to say about the BDP-1: https://community.roonlabs.com/t/huge-number-of-lost-pcm-samples-in-network-endpoint-output-alsa-software-device/13182/15
RAAT and MPD are really very different systems. One is a media player. The other is audio distribution infrastructure designed to produce interoperability across dozens of manufacturers + DIYers with the absolute minimum of required firmware updates in the wild.
RAAT uses a dynamically defined network protocol. This means that we can fix bugs and make improvements to code running on RAAT devices without waiting for each company to release firmware updates, and without forcing users to go through manual update processes. Dynamically defined network protocols present a different workload than inflexible “baked-in” protocols, and also a different workload than decoding media (which often benefits greatly from CPU features like MMX/SSE).
Exactly how each kind of thing plays out on each device varies based on too many factors.
The BDP-1, in particular, is somewhat unique among Roon Ready devices: it uses a rather primitive embedded x86 CPU 10. It is cache poor, and fairly archaic in its approaches to branch prediction, out-of-order execution, etc. It does have MMX, though. This combination of tradeoffs would make a workload like RAAT (primarily protocol unpacking, interpreting dynamic network protocol, packet reassembly) more challenging for that CPU than a workload like FLAC->ALSA (MMX and memcpy).
Overall, I don’t put huge stock in this sort of comparison. Assuming Bryston has done their job well, and I believe that they have, modest differences in CPU usage should not be allowed to impact the sound quality. There is a lot of “it depends” in constructing a test and measuring this sort of thing. I brought up “differences” in CPU usage patterns to draw attention to the fact that RAAT and MPD take extremely different approaches to audio playback, not to suggest a mechanism of causation for a particular anecdotal report.
This is a good overview of the design goals of RAAT. 21. It might be a little bit surprising how much non-audio-related stuff is required to make a protocol like this successful. Getting audio playback right is just table stakes.
MPD probably creates less noise than Roon within the BDP device itself. MPD can be done via network NAS, USB ports, or internal SATA. The internal option should involve the least processing and thus the least noise, followed by USB, and then network. That's how I've put it together in my head based on comments from different manufacturers including Bryston.
All this so far has to do with noise created by the device itself. The goal is to minimize it. There can also be noise from external USB and internal sources such as hard drives or SSD. In the past I've done comparisons with portable USB hard drives and flash drives and did note differences which I've posted on this forum. I've not tried full sized SSDs with the BDP. I'm not sure how all these compare electrically to each other. Chris has hinted at the billions of transistors of SSD previously. James on two occasions has recommended mounting a rotary drive internally. I'm not sure if that was geared from a sonic and/or value standpoint. The 2.5" 5400 RPM portable WD drives I have are inaudible from 2 feet away in a silent room. With music playing at low levels, they become completely inaudible from any distance. You have to touch the chassis to confirm whether they are spinning or not. Thus, they behave like SSDs as far as acoustic noise levels are concerned. Only their electrical properties remain of importance, along with transfer speeds.
Additionally, I'd have liked to known where the level of noise from these various external sources compares with the noise generated from internal processes such as RAAT or MPD, and if there is a hierarchy of what's the most important when it comes to SQ. You'd need Bryston's measurements or your own measuring gear to empirically answer this. Or you could use your own ears. With me, I can typically pick up the differences and do it consistently, but can find it tricky to answer "what's best?" Everyone's internal audiophile barometer differs as to what's best or if A vs. B sounds better.
Until then:
OK I'll bite.
At home and at shows I use MPD with an internal rotary USB drive. :)
james
:popcorn:
witchdoctor
« Reply #84 on: 16 Dec 2018, 03:01 pm »
Strictly for streaming Tidal how does the BD Pi compare to the BDP-3?
unincognito
    • bryston.com
« Reply #85 on: 17 Dec 2018, 01:59 pm »
They just add more platters
https://m.newegg.ca/products/N82E16822179104
Chris
Grant Hill
« Reply #86 on: 18 Dec 2018, 08:16 am »
thank you Chris! would you reccomend that Seagate as internal drive for BDP3?
unincognito
    • bryston.com
« Reply #87 on: 18 Dec 2018, 11:35 am »
I haven't heard of any boot problems as of yet with the BDP-3, but you may need to place it in service mode and have us format the drive remotely though.
Chris
Grant Hill
« Reply #88 on: 18 Dec 2018, 03:44 pm »
Chris
thanks a lot - this was just out of curiosity, so no issues at the moment
« Reply #89 on: 15 Jan 2019, 03:37 pm »
Hi Folks,
I have an English translation of a recent German review on our Bryston BDP-3 Digital Player in HIFI Magazine for Digital HiFi
My thanks to Peter Ullman for yet another translation.
Peter is 95 years old and still an avid audiophile with an excellent system. Peter recently lost his wife of 72 years and I thank him for his commitment to our hobby and his help over these many years undertaking our many German to English translations.
Much appreciated Peter!
James
Email me if you want a copy - [email protected]
dubkarma
  • "God made man because he loves stories." - Canetti
« Reply #90 on: 22 Jan 2019, 05:06 pm »
I installed a 2TB SSD drive in my BDP-3. One of the messages I get is "cannot create file directory."
Worse than that, the BDP-3 now no longer recognizes the external hard drive I was using. So I've got an expensive metal box!
On top of that, compared to Roon, using the BDP software is positively baffling.
Very disappointing! Plugging an HDD or SSD into my Oppo or MSB player, by contrast, works flawlessly.
I'd sell the BDP-3 except I cannot in good conscience offer for sale a component that doesn't work.
After 30 years, the first Bryston component I must warn friends to avoid.
unincognito
    • bryston.com
« Reply #91 on: 22 Jan 2019, 08:38 pm »
If you place the BDP into service mode and email us the service id we can see what wrong with the SSD remotely and possibly resolve the issue.
http://support.bryston.com/downloads/BDP/Manic%20Moose%20Manual.pdf
Chris
wplash666
« Reply #92 on: 27 Jan 2019, 05:21 pm »
I absolutely love the BDP-3!!! ( It made it possible for this poor boy to get a  fairly new 2016 model BDP-2 for less than 1/2 price. Best sounding piece of gear I have ever owned.)
dubkarma
« Reply #93 on: 31 Jan 2019, 05:46 pm »
I find an imported aiff file to sound better than than Tidal lossless version.
I find .aiff and .wav files made from my ripped CDs, stored on the BDP-3 on an internal SSD, sound better than Tidal lossless. I also find they sound better than the same files accessed from an HDD on my Qnap NAS.
But, I have to say, CDs played from my MSB transport to the same DAC I use with the BDP-3 sound better than the same albums saved as uncompressed computer files. I suspect that's because of the MSB Pro i2S connection between the transport and the DAC vs. the AES connection between the BDP-3 and the DAC.
However, I'll soon be installing MSB's network renderer in the DAC and that may level the playing field. . .
On the other hand, I can't figure out how to transfer music files to or from the BDP-3 without removing the internal SSD drive and downloading them from my computer. The BDP-3 shows up on my network, but any attempt to access it over the network produces the message "Connection Failed."
Any tips appreciated!
unincognito
    • bryston.com
« Reply #94 on: 1 Feb 2019, 04:43 pm »
The BDP creates a network share for each drive attached to it, you should see the BDP as a network share.
Chris
matthewpartrick
  • vinnierossiforum.com
    • The Clueless Audiophile
« Reply #95 on: 1 Feb 2019, 05:03 pm »
18 months into ownership and this gem still shines brightly.  I currently have it streaming to a Vinnie Rossi LIO DHT PRE and DAC2, through a VR 120 amp, and Joseph Audio Pulsars.  An excellent setup!  I'd still like to enjoy MQA in full rendering, just sayin. :)
dubkarma
« Reply #96 on: 2 Feb 2019, 04:14 pm »
The BDP creates a network share for each drive attached to it, you should see the BDP as a network share. Chris
Not sure what a "network share" means, but, as I said, I have an icon for the BDP-3 in my Network section, but the only thing I can think of doing is to double-click on it and that invariably produces the message "connection failed."
unincognito
    • bryston.com
« Reply #97 on: 5 Feb 2019, 05:25 pm »
might help us to give you more accurate direction if you could share if your using PC or Mac.
Chris
dubkarma
« Reply #98 on: 5 Feb 2019, 05:50 pm »
Sorry—should have mentioned platform.
iMac running OS Mojave 10.14.2
All the drives, etc. on my network appear as icons just as does the BDP-3 icon.
The difference is that when I click on, say, the icon for my Mac laptop, I have instant access to it, but when I click on the BDP-3 icon, I get that already-mentioned "connection failed" message.
SFOX
« Reply #99 on: 5 Feb 2019, 11:23 pm »
James
Couple BDP-2 questions ...
Does Bryston have any new BDP-2 units left in stock ?
When did the IAD start being installed in the BDP-2 at the factory ?
Steven
