0 Members and 1 Guest are viewing this topic. Read 2432 times.
I recently put a different CD player into my system (it's an Onyx) and it sits on the shelf above my W4S STi-500. When I hit the button to skip a track on my CD player remote it shuts off my amp (and doesn't do anything to the CD player). Has anyone else had this happen? Aside from removing the CD player from the rack or take it out of the system is there a possible fix? Thanks, Brett
G Georgopoulus, So it's the cdp remote that's gone bad? Its funny as only a couple CD remote buttons affect the amp.
Brettio, I looked up your amp, from the image you posted it appears to be a STI v2 integrated amp with a fully functional remote control capability. It looks like you can can now control two pieces of gear with one remote. I would say you have some overlapping control codes. Not an uncommon occurrence in this day and age. The remote for your integrated amp may also control some functions on your CD player. This may be a pain in the ass, but I don't think anything broken.Scotty
I've had this happen with my Ayre and Auralic gear. They must have used the same IR codes and one would control the other. The solution was to cover up the IR sensor on one piece with a small piece of wood or tin foil. The only other option is to replace the Onyx CD player with a different brand.
