0 Members and 1 Guest are viewing this topic. Read 16599 times.
I prefer to replicate the recording the best as possible.
I've spent more money on music than I've ever dreamt of spending on gear. That's the buy; the gear is just fine.
I guess my point was this - the difference in accuracy between a good tube amp and a good SS amp is miniscule compared to the cone/dome drivers coupling to the air. And that is even more minimal than the speaker's interaction with the room. The distortion introduced by the drivers and by the room is massive vs the distortion introduced by the electronics. I think this is why so many people are looking at constant (narrow) directivity speakers (box speakers) and more people are going open baffle. Both designs couple better with a typical room. A step in the right direction I think, but even the best CD and OB speakers are still by far the biggest sources of distortion in the system.
Replicate? Of what?
I hope that helps, and sounds maybe a bit dumb
I wouldn't say I entirely agree with that. Distortion figured are only in the voltage domain, for one. It's basically impossible to make the best speaker ever be truly good if the electronics can't keep up.For speakers we've been working on compensating for the electrical problems in crossovers, in ways not used by anyone yet (that we are aware). That's the first goal before we get carried away with developing crazy speakers. We are planning to make a speaker. For example it's not that we think CD is wrong, but we aren't focused on that first because frankly there's so much else going on that it's not our first concern. Working with a cone and dome, so to say, has been very fruitful thus far, to lead us into something. In my mind without compensating for crossover and driver electrical issues you are faced with squeezing whisky from rocks in terms of room treatment etc. But that's coming from having electronics that can back it up. Active setups may or may not work around the issues. With driver feedback it should be possible and that's something we're interested in for active speakers in the future. Right now it seems easier to get what we want from passive, as the crossover allows you to work with the woofer driver, almost like a reactive shield, instead of just changing the load on the amp without the driver changing. That's a bit premature to say... But so far it's true. What Do we actually hear? Well IMD sound you're use to is something you have to search for... every album sounds totally different. Stand up bass, well, is standing, banjo's speed is natural. You just give up on needing to reason with half the stuff you listen for, because you're hearing music. Things aren't standing tall saying "look at me". But it's very easy to understand how much you hear the studio between you and the music. That's why some stuff sounds extremely natural, in the room, and other things clearly are adjusted and changed a lot. I'm blabbing on when the most concise way to describe the goal and sound is that it's very natural when the album has the ability to sound that way. Some album's sound very raw, which is usually optimal as then a guitar has the sound size you would expect from a real one, not the fake outline of a guitar you often hear in systems saturated with noise to make the imaging unreal.
Folsom, good replication = HiFi,you're on the right path,regards,George
How does one define 'replication'?
Sorry no insult intended,as of the definition of replication,Folsom's posts are good enough for meBest Regards
I guess I was wondering as to how I can judge the quality of my replication to know if I am also on the right track?
I am sorry but this sort of rhetoric is exactly why I am so tired of this hobby. So much talk about something which all eventually leads back to the discussion of perceived sound. I apologize for the insult. I just don't feel like anything outside of metrics and standards based focus is going to provide any real improvements going forward.
Just crank up your imagination like the rest.Oh and in 2017, science illiteracy helps too. Especially with Blumleins creation
If you're implying I don't do a bunch of research projects, like a large university, you're correct.Thing is, I get the impression what you erroneously mean to say is engineering. Now that's worth a . By all means start telling me about how you work to improve the complex-impedance in speakers. Oh and don't forget how you work to meet Ott. specifications or exceed them... would love more ideas there. But really I'm being facetious, truth is I'd be colored impressed if anyone even was familiar with the concept of complex-impedance and the things actually affecting it in a speaker. (or electronics, that's even more interesting)
