Is this a bad idea?
0 Members and 1 Guest are viewing this topic. Read 5097 times.
nickd
Re: Is this a bad idea?
« Reply #20 on: 13 May 2017, 03:12 pm »
I would use some of the cash from the Super V sale to buy a pair of Danny's X Omni's and a pair of the biggest Rythmik subs you can afford and call it good.
My son and both use the X Omni For surround duties. They excell for that purpose.
witchdoctor
« Reply #21 on: 13 May 2017, 03:15 pm »
Biggest subs need to be appropriate for the room or risk being boomy. Just make sure you get the right subs not necessarily the biggest.
danvprod
« Reply #22 on: 14 May 2017, 06:48 pm »
Agree with most of what the others have said. If you can't make them work for dedicated 2-channel audio, give someone who can the opportunity. Do you have any pictures of them? I think $2500-$3000 for them used is a no-brainer for someone. There is just nothing like the Super Vs near this price point.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #23 on: 14 May 2017, 10:11 pm »
Explain.
Best,
Anand.
bdp24
« Reply #24 on: 14 May 2017, 10:59 pm »
It is not a sub being "too big" for a room that causes boom. It is the eigenmodes of the room being excited that does that, and that can be caused equally by an 8", a 12", a 15", an 18", and a 24" inch (though the lower in frequency a sub plays, the more room modes it excites. All the GR Research and Rythmik subs play low enough to excite all a rooms' eigenmodes), in a 1.0 cu.ft., 2.0 cu.ft., 3 cu.ft., 4.0 cu.ft., or 5.0 cu.ft. enclosure, sealed or ported. Employing multiple subs can help address a boomy room, as can bass traps and, feel some, DSP. The Rythmik plate amp features a single PEQ control, and adding a separate DSP unit can provide more, making reducing more resonant peaks possible.
By the way, one of the benefits of the OB/Dipole Sub is that it excites one less room mode than do monopole subs---the one of the width of the room. One less mode=less boom!
Rfglock
« Reply #25 on: 15 May 2017, 08:38 am »
Here are a few pics of them as requested.
