Budget Planar Tweeter
0 Members and 1 Guest are viewing this topic. Read 2390 times.
zieglj01
  • AV Trekker
« on: 9 May 2017, 10:53 pm »
At Madisound
These look interesting and a good price -- I sure would like to here them -- however, I donated my Siming speakers (Dayton like clones) -- I am going to keep an eye out for some cheap or older RadioShack speakers on Craiglist and Ebay -- it seems that they can play lower than those old popular poly-carbonate 1/2 inch dome tweeters. For someone who wants to mod some speakers, it could be a cool thing and be cheap and cheerful.
https://www.madisoundspeakerstore.com/specials/prd100-planar-ribbon-tweeter-4-ohm/
Phil A
Re: Budget Planar Tweeter
« Reply #1 on: 9 May 2017, 11:14 pm »
If you're looking for the speakers with the old Linaeum tweeters (either Radio Shack's or Linaeum's own speakers) - one can search here too - http://www.adhuntr.com/p/results.html?cx=partner-pub-9413604915893153%3Ao8xsd8d7h7s&cof=FORID%3A11&ie=UTF-8&newwindow=1&q=linaeum&as_qdr=a&sa=Search&m=1
zieglj01
  • AV Trekker
« Reply #2 on: 9 May 2017, 11:37 pm »
I owned some of them in the past.
Phil A
« Reply #3 on: 9 May 2017, 11:40 pm »
I did as well.  Gave them away.  Once or so a year I'll look for a local pair just for kicks.
BoJonJovi
« Reply #4 on: 15 May 2017, 03:37 pm »
The Dayton B652 has a pleated ribbon diaphragm AMT tweeter.
https://www.parts-express.com/dayton-audio-b652-air-6-1-2-2-way-bookshelf-speaker-with-amt-tweeter-pair--300-651
Interestingly, you can buy the bookshelf speakers as a pair cheaper than a pair of tweeters alone. Same tweets.
https://www.parts-express.com/dayton-audio-amt-mini-8-air-motion-transformer-tweeter-8-ohm--275-095
