advice on adding Tubes to my setup
0 Members and 1 Guest are viewing this topic. Read 5752 times.
SteveFord
Re: advice on adding Tubes to my setup
« Reply #20 on: 6 May 2017, 09:52 am »
One of the cheap Yaqin tube buffers and some NOS Sylvania tubes would be a good way to get your feet wet.
I.Greyhound Fan
« Reply #21 on: 6 May 2017, 07:09 pm »
There is a great buy on a Vincent SA-31 tube preamp-
http://www.audiocircle.com/index.php?topic=122314.800
BoJonJovi
« Reply #22 on: 16 May 2017, 01:23 pm »
I bought a 6N3 HIFI board and I think the tube sound is great. Very tubular;>}
However, after having to buy a power supply, figure out a case.....I would not go that route again; OK I probably will but not soon.
I think just popping for a built unit might be a tad more expensive when it is all said and done.
My board cost 32, power supply, 20, case shop built and looks like it.
I would do this instead. Actually, I still might.
http://www.ebay.com/itm/2017-Douk-Audio-6N3-Vacuum-Tube-Preamplifier-HiFi-Pre-Amp-Switching-Power-Supply/281873040076?_trksid=p2481888.c100675.m4236&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D099a267c9d0c40a3b2b069fe6ac9cfb1%26pid%3D100675%26rk%3D4%26rkt%3D15%26sd%3D252833378810&_trkparms=pageci%253Ab8d8c3d2-3a39-11e7-bfc9-74dbd180da5a%257Cparentrq%253A1166206015c0aa13c4782104fffe548d%257Ciid%253A1
