toocool4, ArthurDent and 28 Guests are viewing this topic. Read 1798348 times.
Here you go Jim, it was shot with an iPad camera
Geez Bill, now you're just being mean.
That looks mighty amenable to playback, Laura, and not what I expected with your observance of Master Set as I understood it. Thanks.
Jim,I find the current set up very amenable to listeningl. Adding the BOWs really completed the musical foundation/picture in my system and room. I'm sure they're not in the Master Set position anymore. I moved the DA-1.1s a little closer together and away from the wall behind them to make room for the BOWs. I used a laser measure to check distance to listening couch and then fine tuned by ear.
If you like the Runt, get a first pressing of this one.The later ones are really flat and lifeless by comparison.
