Song 3 Encore - the wait might kill me.
0 Members and 1 Guest are viewing this topic. Read 31019 times.
dB Cooper
Re: Song 3 Encore - the wait might kill me.
« Reply #40 on: 26 Apr 2017, 01:16 pm »
If the wait does kill you, would you consider leaving the speakers to me in your will?
LesterSleepsIn
  • Occasionally consternated
« Reply #41 on: 26 Apr 2017, 03:58 pm »
Back off Cooper! I'm his adopted son, aren't I, Daddy.
jsalk
« Reply #42 on: 26 Apr 2017, 06:41 pm »
You really can't compare the two.  The Encores had much better electronics.  $15,000 Wells integrated amp and Exogal Dac and power supply.
Actually, the Encores were being driven by the $3500 Wells Majestic integrated.  The Exotica 3's were driven by the larger Wells amp.
- Jim
DMurphy
    • SalkSound
« Reply #43 on: 27 Apr 2017, 01:04 am »
Jim--what's the power rating for the Wells integrated?
mixsterdude
« Reply #44 on: 27 Apr 2017, 06:42 am »
LOL!!  I hope my wife lets me keep them.  I told her they were bookshelf speakers  :)
mresseguie
« Reply #45 on: 27 Apr 2017, 07:05 am »
Ask and ye shall receive....
TECHNICAL SPECS
150 wpc at 8 ohms
Signal-to-Noise Ratio: -103 db, reference level full power output
Total Harmonic Distortion (THD): <0.02% at 1kHz, at100 W, 8 Ohms
<0.05% at 20kHz, at 100W, 8 Ohms
Gain 30 db
Input Impedance: 50k Ohms
Damping factor: 200, reference 8 Ohms nominal
Power Consumption: 120 Watts idle, 350 Watts maximum
Inputs: 4 pair RCA unbalanced 1 pair XLRs unbalanced
Outputs: 1 pair 5-way binding posts per channel
Operating Voltage: 120V,  230V,  at 50 or 60 Hz
Dimensions: 17 in. W X 5 in. H X 16.5 in. D
Shipping weight 35 pounds
TWINSKI66
« Reply #46 on: 22 May 2017, 10:50 pm »
I have some production on my S3E order (23%).  The cabinets are glued up.
mixsterdude
« Reply #47 on: 23 May 2017, 05:16 am »
Sounds like ours are being built side by side.  Mine are at the same step in production.  What veneer did you choose?
TWINSKI66
« Reply #48 on: 23 May 2017, 06:25 pm »
I chose curly walnut veneer with dark walnut dye & satin finish (retro look)
mixsterdude
« Reply #49 on: 23 May 2017, 10:18 pm »
That will look beautiful!!
TWINSKI66
« Reply #50 on: 23 May 2017, 11:06 pm »
Did you settle on a finish?
mixsterdude
« Reply #51 on: 31 May 2017, 05:00 am »
I'm sorry for the delay, I didn't realize you had asked that question.  Yes, I decided to go with the Pau Ferro Rosewood.  I really agonized over the decision but I kept coming back to the rosewood.
abd1
    • DailyFrenchie
« Reply #52 on: 31 May 2017, 03:10 pm »
that's probably my favorite veneer as well. Can't wait to see  how they turn out. I'm hoping to be able to purchase a pair in the same veneer next year.
mixsterdude
« Reply #53 on: 31 May 2017, 03:43 pm »
There are so many beautiful veneers!!  Now I gotta get busy building my media cabinet.
TWINSKI66
« Reply #54 on: 31 May 2017, 04:45 pm »
Gorgeous veneer pick!  Good luck on the media cabinet.
abd1
    • DailyFrenchie
« Reply #55 on: 31 May 2017, 04:46 pm »
I wonder if Jim could build the speaker so they could have 2 grill options. One as a full length grill that's already included and then another that only covers the bass driver. That way you can see the RAAL, midrange and wonderful veneer more but protect and cover the lower bass driver. Could both be done on the same speaker? Something like a round cover similar to what's on the SS8's on their sides.
hearditontheX
« Reply #56 on: 31 May 2017, 05:14 pm »
I suspect all you need to do is ask Jim!
jsalk
« Reply #57 on: 31 May 2017, 05:23 pm »
It certainly could.  However, it would be a "custom" project as we would have to design the second grill and install magnets for them (there are only two magnets under the woofer, so more magnets would be required).  With the extra magnets, grills and engineering, it would be about $120.
- Jim
abd1
    • DailyFrenchie
« Reply #58 on: 1 Jun 2017, 02:36 am »
Thanks! That's good to know and well worth $120 in my opinion so one could see more of the beautiful cabinet work and finish.
Grbluen
« Reply #59 on: 10 Jun 2017, 08:05 pm »
@TWINSKI66
No updates?
Curious minds want to know. I think I'm more impatient than you are!
