0 Members and 4 Guests are viewing this topic. Read 223337 times.
ok, guess I always associated you with it cause of the photo.I wouldn't get that sub anyway, I'd do a distributed bass solution for even bass in the room be it 2ch or mch.
Right. FWIW, the two top engineers at JBL recommended the DCi. The one uses DCi on his personal system with M2's and obviously he can have anything he wants. I'll also add that after my specific amp questions there was no doubt that the DCi was the way to go unless I was into spending more money (which I was more than willing to do) that was unnecessary. Also important to note that JBL wouldn't go through the process of tuning files for different amps if it wasn't sufficient. The way they do it is quite resourceful so they wouldn't waste their time if it didn't meet specs.
Great thanks to you man!!!I've been having my M2 for over 2 years without being able to listen to them. After buying them, I got some shortage and couldn't put $6K in dual ITECH'sand was still hoping to get that cash soon.I just came across this DCI and did some research which brought me to this thread.I just I can't express my happiness to know that I can finally have my M2 to sing for me after long wait...
My only change is the dac. Now have the Topping D90
Didn’t you have the Mola DAC before?? Is the Topping superior, or do you just find the differences negligible?
