But you COULD connect via BLU-Net to the Crown DCI4 running pass through
That defeats the whole purpose! I'm going to try to finish the output wiring on Wednesday and try each channel to make sure it's all working.
If we haven't figured out Jason by now, this is a man of less complexity, more simplicity, less drama and more music Best Anand.
Here’s one screen shot of HiQnet London Architect 6.0. I’ll post more once I get it all working.
Hey guys, just passing through yer thread here... Tom, you seriously need to change your avatar pic! gone are those listening days!
ML532 being Mark Levinson 532 amplifier?Thanks,Anand.
Very nice! The BLU 50 doesn’t have CobraNet so I won’t be able to try that which is fine.
The big advantage of BLU-50 is fanless and possibility of battery power.
Fanless is exactly why I bought it, but I still had to dim all those flashing LEDs
So you're using Ncore setup like the Crown, through DSP?
After some amp testing and swapping I've settled on four channels of the Hypex NCore NC502MP. Absolutely stellar!
I’m using the BSS BLU 50 loaded with the M2 tuning and the amps from that. Make sense?
Jason I was under the impression you had settled on the AS1200 amps, looks like the Hypex kicked the Crown and AS1200 to the curb??
Yes, exactly how I imagined. That's interesting to note the sound is so good with another amp(s).
Probably should add the chain:2 ch Setup:Motorola Modem sb6141> Emo Systems EN-70HD > (5) eero > Synology 1813+ (DSM 6.1), 4TB Seagate NAS Drives, 4GB RAM & Zero Surge & APC XS BX1000G/backup to Synology DX513) > Emo Systems EN-60KDS > Roon > PS Audio DirectStream with Bridge II > BSS BLU 50 > (2) Hypex NCore NC502MP > JBLM2 Master Reference
